School me on extended lugs for my Skyline. The fronts are easy to come by, but I am hearing mixed things about the rears. Can you guys confirm or deny:
- The rear studs are a different spline than the fronts.
- My car shares studs with the 300zx.
- What is the stock lug shank length?
- How thick of a spacer can I safely run with the stock lugs?
I am working on fun summer wheel options and the wheels I am keen on will require a 10-12mm spacer.
Any help is appreciated, thanks all.
Whether or not you need extended studs will depend on your wheel type. My Stagea has different front and rear splines.If you are using aftermarket wheels you may need hub centric adapters as well. When buying studs (if required) the advertiser should be able to tell you what they fit. 10mm spacers should be  hub centric like this (you will also find extended studs on this site):
http://www.gktech.com/index.php/products
4/5x114.3 10mm hub centric slip on spacers
I'm looking at BBS LMs currently. I have the hub-centric stuff handled (I work in the VW world and we deal with that as well). So far, the stud sellers are able to indicate how much longer than stock (i.e.- 10mm, 20mm, etc).
and, if you look at the site I sent you, the diameter. If you don't know what size your studs are email GK Tech and ask. On my Stagea the rears are bigger than the fronts.
Just looked over their site, they have a handy chart in each lug listing and have options for the front and the rear. Thank you for that link!
