Pre production nismo er34
Rare pre production Er34-000131.Built 5/98,
1 of 5 ev1 yellow cars in the pre production run of 30, feature car used for nismo fr street parts catalogue, Can be found in Gtr-registry.com. Owned by 32yo mature enthusiast.
Car was exported on the 10/06 with 83400km, currently sitting on 92xxx.
All export documents, Dereg and shaken reports available along with owners manuals, dealer brochure/price list and Nismo catalogue/ paper work found under the rear seat.
Car spent some time at nismo paddock/omori, has the catalogue less rear wing fitted.
Nismo r tune coil overs
Nismo sway bars
Nismo lmgt2 18x9 with centre caps, new 265/35 semi slicks
Nismo s tune front bumper
Nismo 2 way gt LSD
Nismo super single clutch
Nismo slave cylinder
Nismo triple gauges
Nismo dash cluster
Nismo s tune stripe kit
Nismo gt led tail lights
Nismo smoked bumper indicators
Nismo smoked guard indicators
Nismo r32 n1 boot lip ( not fitted,but painted ready to go on)
Moonface/superlap jp tension rods
Moonface/superlap jp roll centre adjusters
Moonface/superlap jp rack ends
R34 Gtr 10 point under body brace
R34 Gtr front seats
R34 Gtr v2 aluminium pedals
Superior auto carbon gear/radio surround
C's short shifter
Car has been in storage for the last year and has had a lot of preventative maintenance done and new oem parts fitted. I intentionally made the engine setup look factory, whilst waking it up. All standard parts are also available with sale.
Hks3037pro s turbo, .86 rear
4" stainless intake, z32 afm, apexi power filter
Hpi low mount 304 manifold
Turbosmart 48mm progate with 316 screamer.
3.5" dump pipe, 3.5" hks SuperDragger with jasma step down removed from rear can.
Apexi delta fin intercooler
48mm ally rad, nismo thermostat
R35 Gtr 570cc oem denso injectors
Twin Walbro gs342 in tank pumps
Power fc with add on boost control kit.split fire coil packs
New oem belts fitted.
Motor was rebuilt by previous owner, has Ross 86.5 forged Pistons, cometic head gasket, arp head studs, new bearings/oil pump/waterpump/gasket kit.
Car was tuned by dvs Jez in October, Comptest/leakdown/smoke test inlet, on gate pressure, 18psi with no timing in it, comfortably made 270rwkw @ 85 percent duty cycle on 98oct, fuel being the limiting factor.350rwkw is there for the taking with a set of 1250cc injectors and an e85 tune.
Car was pulled down/inspected and resprayed in fresh ev1 by medicar, campelltown, no accident damage or rust was found.chassis rails are straight and not crushed from incorrect jacking like most, factory under seal still in place (no cover ups) Car was painted inside and out with the exception of the engine bay and underbody.Car was completely cavity waxed to ensure its survival for the next 20 years.This was not your typical cheap respray that are the flavour of the week.new oem weather trims were fitted.
New xenon headlight housings were also fitted.
Car has been ceramic coated with opti coat including glass.
all electrics work as they should, climate control works as it should,
stereo is a basic Sony cd player and alpine type s 6" speakers front and rear.
Will not find a cleaner Gtt unless Nissan Japan has one tucked away.With the prices of 34gtr's skyrocketing and Gtt's slowly climbing in price as they're being exported to Canada/China/USA, this represents a great investment and bang for buck. Currently insured with NRMA vvc for 25k, awaiting an increase in cover, after appraisal.
Car is currently unregistered/in storage in a climate controlled garage as I have no intention of putting kms on it, can arrange rego for buyer.Can also accommodate a permit to drive for interstate purchaser or interstate freight.High res/detailed photos upon request.
Car will only be pulled from storage once proof of funds are made available.
Mechanic / specialist inspection welcomed under my supervision.
Firm on price, plenty of wound back r-grade cars available for less.
Only selling so I can free up space to work on my Gtr.
Please do your research before contacting me, as to what this car represents and ONLY contact me, if you're a serious buyer.
i am not interested in swaps
located south of Sydney,nsw
Car can also be found on carsales
0410252456
[email protected]
Thanks, Tim
https://www.sau.com.au/forums/topic/468406-pre-production-nismo-er34/
Short 1-3 pull video on the highway on the way home from jez's, the 3037 sounds like a baby t51r before the gate opens, makes full boost by 3500rpm. Very fun car to drive
IMG_6051.MOV
IMG_6053.MOV
IMG_6051.MOV
IMG_6053.MOV
What were the vids about , hard to see anything except the dash :(
Need something different :)
Only have these 2 videos of the drive home from Jez's on my phone. They were more so recorded as I was impressed with the sound and tone of the 316 screamer I made/wanted to share it with my friends at the time
Jez does a good work, I like the yellow ,  I have not seen one before. Do not mind the work on the side and I do not usually like that type of thing :)
5 minutes ago, Livinlahtimmah said:
They're nismo s tune stripes, extremely hard to find decent fitting items as the originals are no longer produced. Mr fijigold helped me procure the set :)
They blend in nicely with the cars profile
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
