Need more radiator
I currently have a Cooling Pro Triple Core 40mm from Just Jap, but I need more cooling at the track.
With respect to design, here's my current set of assumptions;
- Number of rows does not make a huge difference
- Number of passes probably makes more difference than number of rows
- Thicker core should be better
So I should probably get something with ~50mm core and two or more passes
Options;
Blitz Racing ZS 42mm, just jap, $600 or rhdjapan $399+delivery
KOYO Copper Radiator Type-S, "Num. of Layers: 2" $436+delivery
TRUST GREDDY TW-R 50mm, "2-Row" rhdjapan, $436+delivery
HPI Radiator Evolve STD Series, 50mm, "Wide Tube 2 Core" rhdjapan $492+delivery
KOYO Type F Aluminum, 48mm, "Num. of Layers: 2" $802+delivery
HPI Multi Flow Evolve, 40mm, "Multi Pitch Core (Triple Turn)" $871+delivery
Does "layers" mean cores or passes? Any recommendations from this list or elsewhere?
https://www.sau.com.au/forums/topic/468413-need-more-radiator/
Yep have oil cooler. Until the last power upgrade, I'd get to about 110 on the factory oil temp gauge, and the coolant temp would stay at half way on the factory gauge. Now coolant gets to 3/4s quickly.
these 2/3 core radiators aren't actually twin or triple pass are they?
Best bet would be to talk to a local radiator shop about making a custom twin pass radiator wouldn't it? Presumably that would mean sideways end tanks but shouldn't be to hard to make work in a skylien
Just the HPI Multi Flow Evolve, but its only 40mm according to RHD.
JJ has its "HPI Evolve" at 50mm, and the add says "Provides 30% Increased Cooling Efficiency".
50mm is probably 30% thicker than a stock core. 50mm is a thick radiator. Generic ebay 50mm core In mine doesn't get hot, or didn't.
End of the day its a trade off, Thicker is better and holds more fluid, more space for air to pass through, but weighs more takes up more space. Twin pass means you have generally more usable area used which is a plus, eg i'd expect that HPI actual twin pass radiator (nice find!) to cool more effectivly than my 50mm normal one... but as i said, would it matter for my usage? no...
If you can afford to drop 750 bucks on a radiator I think you'd go well with the HPI twin pass one, but that's a gut feeling only.
Also - do these things do anything? The bonnet already blocks air from heading over the top doesnt it?
http://justjap.com/engine/cooling/sri-greddy-style-alloy-radiator-cooling-panel-nissan-skyline-gtr-bnr32-black.html
I think cooling panels have an effect. The seal with the bonnet is not that good. SK fitted one to his Stagea early in the piece and he is quite a results orientated person not that much into bling.
They definitely work.  But you have to go the full monty and make sure that the air can't just escape everywhere else.  So that usually means packing the gaps at the sides with closed cell foam and making sure that the undertray/diffuser area isn't open between the intercooler and the radiator.
17 minutes ago, Borci88 said:
The radiators that Racepace sell are triple pass and are about $500.
Looks like their website is dead - i'll message them.
Ok, there's big gaps everywhere.... who sells foam that's up to the job?
Upholstery places, car trimmers? You can get stuff with adhesive for the strips.
If anything just adding foam to the top of the radiator support, if it isn't sealing, will be exactly as effective and much cheaper than one of those cooling panels. Also the SRI ones dont fit over the AC lines.
I'm concerned that generic stuff wont last long with the temperatures and fumes... too paranoid?
Why not PWR? They are the choice of major motorsport teams.
Also how much glycol are you using? The less the better for cooling. You really just want anti-corrosion and some gycol as lubricant.
And adding some panels/shrouding will definitely help.
I used the grey open cell stuff that is often used to pack IT equipment and the like.  Open cell is not as effective, but for pieces that are 2-4" thick and getting squeezed into gaps, it hardly matters.
Self adhesive is only so-so useful.  To get the stuff into the vertical spaces you need to poke and prod it.  It's worth shaping it a bit to fit the obvious profile, but just make it fatter than it needs to be and ram it in so it stays put.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
