Need some input on my Neo build and ITB's
Hi all,
I have done a bit of reading but nothing quite definitive has come of it so I have a few questions to ask to the more experiences fellows out there.
Long story short is.. I am wanting to build up a forged Neo motor on the side with rb26 itb's. I am in no rush as my current motor in my R34 GT-T is just fine (touch wood) so I do have time on my side and I will be doing all the work myself, i have built a few motors before but no rb's yet, this will be my first RB build.
I am really liking the combo of solid head + vct + itb combo so I am trying to determine the most effective and sensible way of doing it.
First question I have is.. Are R33 and R34 blocks the same? I have bought a mint R33 s2 short motor for really cheap which I plan to put 34 neo forged pistons and rods into, a long with a neo head.
Is there any issue with this or are the blocks identical once pistons and rods are taken out of the equation?
Second question, if i want to run ITB's, has anyone had success with an adaptor plate to fit rb26 itbs? Where are they sourced from these days?
As for the turbo side of things, I am leaning towards a gtx3076 on ethanol but I will concentrate on that later.
I am fairly certain RB25 vanilla/neo blocks are identical.
Otaku garage sells adapter plates for RB26 plenum onto RB20/25. I just purchased one last week and am waiting on it to be delivered. Can post back with pics of it once I receive it.
With a 25 head though the VCT solenoid needs to be relocated. Check Forge Performance on Facebook, they sell a nice looking adapter kit.
  • Like 1
If I were building an ITB RB engine other than a 26, I would not use RB26 TBs.  They are old, they are famously annoying to get to seal, often requiring a great deal of stuffing around to get them working properly.  Given that you have to go to the expense of buying ITBs and an adapter plate, and then possibly having a leaky piece of shit that won't work until it has emotionally broken you, I can't see the sense in not looking for an alternative using new off the shelf TBs.  I would be thinking of DCOE pattern TBs as a first option, or if the sizing is not helpful, looking at 6 separate TBs.  The only hassle here is linkages and synchronisers, but these are generally available from the same people that make the TBs anyway.
My bro-in-law did this to a 2JZ-GE using TBs from a 20V 4A-GE.  Looks proper good.
  • Like 1
Thanks mate, I have added them on FB and found the adaptor kit! Pretty well priced.
Haha I know where you are coming from, I used to own an R33 GT-R and I made the mistake of cleaning the TB's in the process of installing my PFC DJ ecu and was stuck with 1100rpm idle when I put it all back together.
A bit of tomei throttle paint did the trick though. Honestly If I can get my hands on an itb set for around 300 bucks with the plenum, it makes it very feasible.
/\ This.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
