Turbo Lines Help
I have just finished re-turboing my r33 gtst but i am unsure where all of the vacuum lines need to connect. The first photo shows the t-piece with A going to the blow-off return pipe on the intake of the turbo. B goes to the waste gate actuator and C to the boost controller (with the other controller connection going to the intake). IS this correct? and does it matter which side plugs into the  connectors of the boost controller (currently the t piece goes to the bottom of the controller)
Also this may or may not be related but there is another random hose left unplugged on the drivers side near the boost gauge (but isn't the boost gauge line) that disappears down into the body work. its also not the rear windscreen washer either.
I bought this car off an older guy a couple years back and was given the turbo pieces in a box with them assembled roughly as seen in the photos but i have learnt to not trust him after seeing his electrical work (exposed, permanently live wires simply twisted together and run across the airbag sensor) so i have little faith that it is correct.
Cheers in advance,
Joe
https://www.sau.com.au/forums/topic/468462-turbo-lines-help/
Been a while since I saw a stock set up but ...Boost signal comes from the nipple on the intercooler pipe just above the letter A  to a T - one line (C) goes to the bottom of the boost solenoid valve and the other (B) goes to the turbo actuator.
Originally there is a restrictor in the line but can't remember just where sorry.
The line from the top of the boost solenoid goes to the bov return pipe. Not sure why you have a red line going over to the plenum. The other lines from the plenum go to the BOV and one to the FPR
Just looked at mine , that fitting on the front of the plenum goes to the fuel pressure regulator hose .
The rear plenum one goes to the standard boost gauge solenoid box gadget .
Non standard boost solenoid here but one side goes to the waste gate actuator and the other the barb on the steel IC return pipe that feeds into the cast aluminium crossover pipe .
A .
Ok so the last picture i posted wasn't at the best angle (it looks like the random hose i'm holding is going into the FPR bung). Turns out i shouldn't trust anything on this car, the hose i was holding ran into the body work but i found the other end and it was plugged up (the guy who owned it had a habit of running extra/unneeded wires, like the 4 set of RCA leads to a single sub). Cheers for all the help guys i've finally got my head wrapped around this mess and now all i have to do is plug the hole he added to the plenum to run what i think was a boost gauge.... some people...
Cheers again.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
