Purchasing 2003-5 V35 with 100k+ kms - tips?
Hi all,
Background - I've never been a hardcore skyline fan like some but I've was a fan of the 350z as a kid. I first came across the 350GT a couple of years ago simply walking past it in the street. I stopped and walked right around it. It is an amazing looking car. Now I'm looking at getting a new car and the more I read about it the more I'm thinking about buying one!
Question(s) - How are these cars at over 130-150,000 on the clock? They're getting on a bit and I'm not someone who is going to have time to do much maintenance myself. Should I be expecting to sink 1000's each year I own one? I the answer to this question changes on a car-to-car basis, but generally what have your experiences been now that these cars are getting a bit long in the tooth. As they are imports I understand that many have unreliable odometers. What else can I look at to get an idea about whether the car has a good five years of use left in it?
Thanks for your help and advice!
I used to own one. They are a phenomenal car, although they do love oil. Mine hit the 150,000km mark before I sold it and I could not fault how well the car performed. If you are purchasing make sure to obtain the Japanese de registration and auction paper to validate the grade and mileage.
Mechanically, they are a 350Z.  as said check japan history before you buy privately.  if you want to import your own, use a reputable importer.
The pre 2005 models do have some issues with window motors, and synchro issues on the 6sp manual.  there are some common failure items, like front suspension bushes, and crank angle sensors, but nothing major.
  • 2 months later...
  • 5 weeks later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
