On my old Subaru Liberty & Forester ECON would cut out the compressor if any medium- heavy throttle application was applied so putting less load on the engine
Also would put the system in recirculate so it would ease the load on the aircon
Edited by Watermouse
https://www.sau.com.au/forums/topic/468476-climate-control/#findComment-7802869
I think it allows the compressor to diseneage when the cabin temp is low or at the set temp, but outside temp is high, rather than just pulling the heater in.
I have the G35 manual somewhere, i will check when I can.
https://www.sau.com.au/forums/topic/468476-climate-control/#findComment-7803037
This is what the G35 manual says -
Economical operation (ECON)
Economical operation reduces some load
to the engine to improve the fuel economy.
It allows higher humidity than normal operation.
Pushing the AUTO/ECON button changes
operations as follows while the A/C button
indicator is on. AUTO!ECON!AUTO
https://www.sau.com.au/forums/topic/468476-climate-control/#findComment-7803205
That's for the info.
My past cars the ECON turned the A.C off.
Cheers.
https://www.sau.com.au/forums/topic/468476-climate-control/#findComment-7803242
