Tuning HKS FCON V
Parag0n
 Share
Hi,
I need someone in QLD who can tune this ECU, Gavin Woods can't, Sub-Zero can't, all the HKS dealers can't.... I rang up BD4's in Sydney which is a HKS ProDealer and they reckon they are the only ones in Australia who can tune this ECU. If anyone knows of workshops in QLD who can do it let it be know :)
Otherwise I will be going on a little roadtrip ;)
  • Replies 74
roadtrip!
but seriously, im very sure BD4's are the only guys who can tune this ecu. another place in sydney does it but the just contract the work to BD4's i think.
-rb25
be careful with the HKS Fcon V ecu's. Not many around australia know how to tune them because most the time the language is in Japanese and u need HKS accreditation to recieve access to the software. Only time i've heard of ANYONE in australia tune one was when Susumu Koyama from Jun Auto in japan went over to perth to tune a few cars (inclusive of a sexy looking grey R34 GTR)
I just spoke to Jim @ Croydon Racing Developments (CRD) and he is trying to source the HKS F-Con S/V laptop software from HKS at a cost of $4000 so he can tune this excellent ECU...
Just remember that actual costs always run nearly double what he quotes you. Keep that in mind and you'll be fine.
;) um, you could pay twice the money to get something like that tuned..
or throw it out and go for one of the common ones that can be tuned by anybody. Its a waste in a way, but unless you can find a good tuner for it, what is the point?
Out of interest, what are the advantages of the HKS FCON over something like the Apexi PFC?
If there is only one tuner in australia who can do FCON, it seems like a lot of effort to goto instead of using a common garden variety computer. Are there big gains to be had?
Ok the deal with HKS computers as far as i know is:
FconV
Does fuel only. Now the bad thing with this piggyback ecu is that the standard ecu will still retard timing and add/remove fuel 7.5% either way of the tune put simply. I like to think of it as HKS's answer to the SAFC. Who would pay someone big money to tune an FconV or FconS when you could get an safc done for 200.
FconV Pro
Does fuel and timing and shitloads of other stuff, comparable to a motec, but still not as comprehensive. With thi ecu you have to buy an air temp sensor and a MAP sensor to make it work, an additional $1000 ontop of the ECU. Also it is still a piggyback, leaving the standard ecu to do aircon and demister etc. the fuel/timing is eliminated with a special harness which isnt cheap too. Tuning was very expensive last time i got a quote, it put me off getting one of these ECU's. Imagine forking out truckloads of money everytime you do a mod just to tune your car to it.
-rb25
Serious question, and not a go at you or anything....
If its a step below the PFC, and you have to drive from the sunny coast to sydney for tuning ... Why use it instead of the PFC?
If there are some magical features ross hasnt pointed out yet (although I guess MAP is an advantage over MAF) I'd be interested in hearing them. Always open to new ideas and suggestions for ECUs :rolleyes:
rb25 the HKS FCON V is worlds apart from the Apex SAFC, maybe one step behind the Power FC, for reference I have the Pro Version and BD4's do have the Pro Software.
for sure, it is more comprehensive than an safc, but at the end of the day, it does fuel maps, not timing, and imho thats ordinary anyway. powerfc is the go.
-rb25
In Perth a guy is flown in over from Japan and all cars a done in one hit, it isnt just about having the gear and software it is all about knowing how to tune the software.
One shop here blew two motors and they hadent started to look into tuning, ripped it out and put in a Micro Tech (RX7).
Power FC is the way or something that a good local tuning shop can work on.
Because it is the pro version, which is proven a better ecu over the apex power fc.
The pro version is pretty much a MoTeC but uses a piggyback system.
And yes RB25 I have the harnesses and what not.
i believe what Krawler is trying to say is ---> Why is it so much better than the Power FC? therefore making the drive to sydney worth it. Why couldnt u sell it buy a power FC and have it tuned here and save yaself alot of trouble
you can now get a newer PFC's will do MAP as well..
i think everybody is pretty much along the same lines though.. $1200 on a PFC, or lots of ****ing around and maybe headaches with the HKS. The HKS may in fact be a better ECU, and I have seen quite a few hypo GTR's with them in japan - and some 9second GTR have had them.. but if you can't get it tuned, or tuned properly more importantly its all a little irrelevent
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
