All parts are in good working condition
Located Sydney wetherill park area will post at buyers expense contact 0434496255
R33 gtr turbos + dump pipes complete very good condition $400
R32 gtr Custom front pipe $120
R32 gtr stock front pipe $70
R32 gtr Decat pipe $50
R32 gtr Stock bov + pipe $140
R32 gtr airflow meters $120
Rb26 intake manifold $120
Brand new Genuine rb26 head gasket $100
Rb26 rocker cover breather adaptors $40
Cusco oil cooler + oil filter relocation kit $170
Caliber Adaptors $100
Stock exhaust mainifolds + shields $70
Brand new MLS metal exhaust manifold gaskets $50
Stock r32 gtr intercooler $80
R32 front and rear strut braces $150 pair or $80 each
R34 gtr stock strut brace $50
HKS mushroom filter $30
R32 gtr boot lid welded holes needs paint $80
IMG_1483777379.628340.jpgIMG_1483777395.529909.jpgIMG_1483777406.847093.jpgIMG_1483777429.067582.jpgIMG_1483777440.815863.jpgIMG_1483777455.485058.jpgIMG_1483777467.820060.jpgIMG_1483777481.267977.jpgIMG_1483777491.338348.jpgIMG_1483777502.353621.jpgIMG_1483777515.425036.jpgIMG_1483777527.539294.jpgIMG_1483777539.689576.jpgIMG_1483777549.173956.jpgIMG_1483777561.474428.jpgIMG_1483777572.641777.jpgIMG_1483777591.642064.jpgIMG_1483777606.427899.jpgIMG_1483777629.130005.jpg
https://www.sau.com.au/forums/topic/468502-rb26-r32-r33-r34-parts/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
