All parts are in good working condition
Located Sydney wetherill park area will post at buyers expense contact 0434496255
R33 gtr turbos + dump pipes complete very good condition $400
R32 gtr Custom front pipe $120
R32 gtr stock front pipe $70
R32 gtr Decat pipe $50
R32 gtr Stock bov + pipe $140
R32 gtr airflow meters $120
Rb26 intake manifold $120
Brand new Genuine rb26 head gasket $100
Rb26 rocker cover breather adaptors $40
Cusco oil cooler + oil filter relocation kit $170
Caliber Adaptors $100
Stock exhaust mainifolds + shields $70
Brand new MLS metal exhaust manifold gaskets $50
Stock r32 gtr intercooler $80
R32 front and rear strut braces $150 pair or $80 each
R34 gtr stock strut brace $50
HKS mushroom filter $30
R32 gtr boot lid welded holes needs paint $80
IMG_1483777379.628340.jpgIMG_1483777395.529909.jpgIMG_1483777406.847093.jpgIMG_1483777429.067582.jpgIMG_1483777440.815863.jpgIMG_1483777455.485058.jpgIMG_1483777467.820060.jpgIMG_1483777481.267977.jpgIMG_1483777491.338348.jpgIMG_1483777502.353621.jpgIMG_1483777515.425036.jpgIMG_1483777527.539294.jpgIMG_1483777539.689576.jpgIMG_1483777549.173956.jpgIMG_1483777561.474428.jpgIMG_1483777572.641777.jpgIMG_1483777591.642064.jpgIMG_1483777606.427899.jpgIMG_1483777629.130005.jpg
https://www.sau.com.au/forums/topic/468502-rb26-r32-r33-r34-parts/
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
