Hey guys. I recently put a 3inch dump pipe on my r32. After installing it i took it for a spin. It felt okay. Then i came to a stop and the car revved to 2k. I tried to accelerate but it wouldnt let me go above 2k. It stalled a few times also.
1 of the nuts that connect the dump to the turbo wasnt tightened all the way because i couldnt get to it. Can this be my problem?
No
If a bolt has come loose the worst case scenario will be an exhaust leal. As it is after the turbine there is no power loss from this. I'd expect noise and possibly a tiny tiny power gain from an exhaust leak post turbo if anything
Id say youve disturbed something while doing the dump pipe. Check all plugs and pipes in the area
  • Like 1
just search your symptoms, i couldn't even begin to explain how many times this comes up.
it has nothing to do with your dump but something else you have affected as said.
i just put 2000 rpm into the search, here are 10 of the 1000 which came up.
if you want another 789674653 threads search afm or cas or missfire or limp mode ect
No one knows exactly what is wrong with your car. Stop obsessing about the dump - it is entirely possible that a fault has developed in your car that has nothing to do with your dump. Start reading some of the links that Glynn has kindly provided.
to simplify the subject, a 2000rmp issue is a redflag for very common issues with RB engines. it WILL be the usual suspects. these are very easy to check and fix. the same answers will have arisen in any thread with a 2000rpm missfire/ hesitation.
have a read in the threads about what they found how they found them and how they fixed it.
when i had the issue the solder inside the afm plug had deteriorated, going over bumps gave me my issue, they could have dried ages ago over time and you dislodged it when you took the dump off. check the plugs, maby resolder them... there is a link somewhere... i know i posted one when i hit the issue.
but there is nothing the dump can do within reason to cause the issue your having now. dont look for unicorns when you find horse poo,
Edited by GH05T
  • Like 1
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
