Hey guys,does anybody know if skylines Australia will be a NSW historic rego club or not?
I think you need to be part of a club for 2 years minimum before qualifying for historical rego,my 32 gtr is an 89 model,so I thought I better get the ball rolling.
Cheers Steve
https://www.sau.com.au/forums/topic/468510-nsw-historic-rego/
It seems that each state forum may be responsible for their state when it comes to club rego. I found this which says it has been attempted but could not get the required minimum 5 cars.
And here is an older thread on the matter.
Looks like a common question but no 5 people at once willing to try it.
Edited by FordyR31
I looked into it at one stage but there are a lot of rules and I doubt most of us would fit into them,
the main ones being
*30 years or older
* in a club registered for historic regos
* must be close to original as possible (only safety features can be changed/upgraded)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
