Newb
Hi guys,
I'm a new member and thought I'd introduce myself. I'm Adz, live in Canberra. I'm the proud owner of a 1988 R31 GX Series II.
I have some pretty big plans for this car, and already have a few parts to add to it, thanks to my best mate. I'm basically aiming for the car to look like the second pic below! :)
My biggest issue at the moment is trying to determine what would be the best suspension conversion (other than s13) for the car being a dedicated track car (hillclimbs, sprints etc)
Any advice is appreciated.
Cheers :)
  • Like 1
https://www.sau.com.au/forums/topic/468528-newb/
i love a good 31 build.
welcome mate
i remember back in the day on the r31skylineclub forum there were coilover kits which you could weld the r31 hub to. these were the best option i saw when going through the motions. the S13 stuff worked but the highest settings were still very low.
**edit**
found it, Angrys kits.
https://www.facebook.com/pg/AngryIndustries/photos/?tab=album&album_id=115545405206002
Edited by GH05T
https://www.sau.com.au/forums/topic/468528-newb/#findComment-7803578
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
