R34 and OBD2
Oi oi
Just a quick question... and I'm really after just a straight yes or no answer on this...
I'm looking at buying a gift for somebody I know who owns an R34 GTT - one of those OBD 2 Head Up Displays, much like this: https://www.kogan.com/au/buy/obdii-car-head-display/ (revs, speed, temp, alerts, etc).
I know the R34s predate 2007, and therefore don't conform to the OBDII standard (even though the 'standard' is actually three different protocols). But I know the R34s have the Consult port.
My question is... if I buy one of those adaptors on eBay to connect the OBD device to the Consult port, will the HUD work as intended?
Peace.
https://www.sau.com.au/forums/topic/468539-r34-and-obd2/
The only person who could give you a straight yes or no is someone who has tried it and I can't imagine why anyone would since as you have already pointed out Nissan Consult is not compatible with any OBD standards.
https://www.sau.com.au/forums/topic/468539-r34-and-obd2/#findComment-7803866
First of all, I asked if anybody had tried connecting an OBD device to a Consult port using an adaptor cable. From your response, I take it you haven't.
So how are you helping me by essentially telling me that you don't know?
Secondly, I didn't say they were *incompatible*, I said that they didn't conform to the standard. There are plenty of instances of pre-OBD cars connecting to OBD devices, assuming the right connector is in the middle. And I'd lay money on the fact that if you plugged it in, SOME data would make it through. I'm just wondering whether it's the data I'd want.
Thirdly, "I can't imagine why anybody would"? Are you serious? People get curious. And I KNOW I'm not the first person on the internet to ask the question that I did, because many googlings proved that to me. So I'm NOT the only person out there wondering about this - but NOBODY is answering.
Edited by Mr Slowly
https://www.sau.com.au/forums/topic/468539-r34-and-obd2/#findComment-7803941
Hi mate. On 1 of my 34's i used an obd 1 consult and it worked only with a normal ecu. Didnt work on my 34 with nistune. So if he is running the stock ecu it should show up stuff like rpm and speed ect ect.. i hope this lil bit of info helps. Have a good day and in the end u can only try.. Cheers mate
https://www.sau.com.au/forums/topic/468539-r34-and-obd2/#findComment-7803949
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
