V36 air intakes
I know many post about air intakes have been made but I couldn't find the answer I wanted .
Here goes , I have the vq35hr engine and I want to get dual air intakes with Australian standards .
I know the best options will be either the kn or stillen . But The money is a bit of an issue and I don't know if it's with all this import . ( tried to find some from wreckers or from Australia with no luck ) so I came up to this one
https://www.ebay.com.au/itm/311737353681
the seller said the sensor may not fit my engine as this item is for the g37 so I am asking will this do the trick ? ( later I will get the pods of k&n and some carbon enclosure )
so is this gona fit ?
Thanks in advance .
https://www.sau.com.au/forums/topic/468569-v36-air-intakes/
just because it has such a cheap price it might be a bit tricky getting everything to fit.
Best to save up the extra 400 dollars and get something better that will fit. Or if you like to custom stuff then take the time and make it work. You would then be saving moving, just spending more time.
Australian Standards? do you mean road legal?
https://www.sau.com.au/forums/topic/468569-v36-air-intakes/#findComment-7804206
I assume that you are doing this for the look and the sound of a pod, as I under the impression that the stock dual intakes can flow enough air to support a reasonable level of engine mods.
Also worth being a little careful of oiled filters and the air sensors... They have been known to get upset if coated in oil...
  • Like 1
https://www.sau.com.au/forums/topic/468569-v36-air-intakes/#findComment-7804263
Yes I am after more of the sound and looks. If there is a bit of performance I would welcome it .
Yes by standards I mean the enclosure of the pods . I found some carbon boxes etc .
Anyone knows where I can find them here in Australia in reasonable prices ? As whenever I have quoted and asked I only found 1000+ .
I want to get the stillen but with all the imports and stuff goes to big bucks . So as I see it with some limited knowledge I have in this as long as I get the metal tubes and can fit the sensor there I can get any pod filter which are cheap and then an enclosure .
I will try to get air filters without oil coating I am more after the tubes .
Also u think this is any good and fit ? As I still don't know if g37 will fit mine .
https://www.ebay.com.au/itm/152153946670
https://www.sau.com.au/forums/topic/468569-v36-air-intakes/#findComment-7804277
Apologies if this comes across rude but if money is an issue, why waste it on silly pods? You won't gain anything useable from it in power, and your car becomes susceptible to defects notices. I would suggest save it and spend it on something you are going to get benefit from. Like sway bars or similar. For the same money your talking about you can transform a car if you spend it smartly.
https://www.sau.com.au/forums/topic/468569-v36-air-intakes/#findComment-7804513
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
