Intro
Hello SAU!
My name is James but I go-by Jay. I hope the start of everyone's new year is going as planned, if not I hope it gets on track. I live in the US and I bought my 1991R32 from Okinawa, Japan to TX, so far its received a warm welcome. I haven't got a chance to push it yet because I have something going on that I hope you guys can help me with. I put it on the DYNO and found out I have a misfire. I opened up the spark plug area to remove the coil packs & spark plugs and all of a sudden I notice that I have coolant in 2nd spark plug well, where would it come from? I cleaned everything and put in new plugs and took in for a spin, the coolant came back :(.
James
  • Like 1
https://www.sau.com.au/forums/topic/468591-intro/
Hi mate, that's definitely not the start to GT-R ownership you would have hoped for.  Basically you've been stitched up by a dodge seller.
There's 3 main possible causes of your issue. 1) Leaking head gasket 2) Cracked/warped head 3) Cracked block.
Either way I'm afraid you're up for a few dollars to fix.  The order of the possibilities above is the order that you would hope for as in just a leaking head gasket would be the most preferrable and cheapest outcome and a new/replacement block and the required mechanical work will cost you a bomb.
Welcome to GT-R ownership where your wallet lives in a constant state of openess!
 I really hope you can get some assistance from your seller (but doubt it) and that when it's all sorted you get to enjoy the car in all it's glory.
  • Like 1
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804356
I shoota_77, thank you for the insight. I need to clarify my post a little bit. I bought the car in Dec 2014 when I was stationed in Okinawa, Japan.
In May of 2015 I bought a rebuilt engine from a shop, the engine came with metal gaskets, tomei cams, r33 crank, N1 oil pump, new and a water pump. I added a power fc, R34 N1 Turbo's, 850cc injectors, tomei fuel rail, sard fuel regulator, oil relocation kit, oil cooler, orc super single clutch, big intercooler, aluminum radiator, boost controller, new coil packs, and plugs.
When I retired Dec 1 1016 the Air Force let me bring my car to the US. My wife is going to kill me cause I have to put more money into this car...the Gtr life lol
  • Like 1
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804366
Oh ok.  I didn't pick up on the time frame!
Fingers crossed it's not too $$$ to fix so the wife doesn't make you trade it in for a Camry and a beige cardigan! (I think you have them there too??).
Hopefully head off, quick skim, new head gasket and you're good to go!
  • Like 2
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804373
Hey Jay, welcome to the site!
As this is the newbie intro's section, this topic wont get much attention from the peeps in the know. I can move it to the tech area for more exposure if you'd like. Although, @Shoota_77 seems to have you covered. :)
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804382
That's a bummer...
If you mean coolant is in the valley around the spark plug and not in the cylinder itself...
I'm going to say head is cracked. If it was cyl 1, 4 or 5 there is a grub screw that may be leaking through the thread but cylinder 2 doesn't have one. No other way for coolant to get in there other than through a. Crack in the head. I'm assuming all other spark plug areas are dry except for cyl 2?
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804442
Its been a while but arent there some plugs up around that area? I assumed they were for coolant but could be wrong. Worth pulling the whole coil pack assembly off i would think if you havent already done so.
Also, its easier to undo the 5 bolts that hold the coil pack brackets in place to do plugs than to pull each individual coil pack off. If it helps :)
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804492
Wow! Thank you for all of the technical information gents, I really appreciate it. It looks like I'm going to have to pull the head off. Question, would you guys get the crack repaired (if it's cracked) or buy a new/refurbished head?
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804537
That depends on what the relative costs are (where you are) and how prepared you are to spend money.  If you drop a lot of money on stripping the head, you may as well rebuild it at the same time (or at least do those things that it appears to need).  If you do this, then you're investing in the future of that head, and to certain extent that engine and that car.  If you've bought an R32 GTR, then you possibly have intention to keep it forever, so in the long term you won't hate spending the money.
By the same token, buying a used running head that you can just slap on means that you now have 2 heads.  And everyone knows that if you own an R32 GTR you need at least 2 of everything!
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804571
Get a quote on the repair first and make a call then.  A brand new bare head over there you'll pick up pretty cheap ($800 USD) so the repair would need to be comfortably less than that to stick with it.  The new head *shouldn't* need machining (but should be checked) so there's less to spend on it but you would still need to get all of your valves refaced to suit.  While you're at it I'd personally throw a set of bigger valves and stronger springs in it and make this into an opportunity to gain something out of a bad situation....
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804572
Great Information Shoota & GTSBoy. I was thinking of saving up some mula and buying a crate engine. I would save my current engine and learn how to build an engine so I can have as Mr. GTS PUT "have 2 of everything"! I'm learning about engines, all of the parts, and how they work. I tell you it's a lot to learn. I now will look up how the valves work and the reasoning for having them bigger and of course why have stronger springs.
https://www.sau.com.au/forums/topic/468591-intro/#findComment-7804575
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
