For a complete novice it would take 4-5 hours if you take your time and document everything.  Get 20 zip lock bags and put all of the nuts and bolts in labelled bags.  Take heaps of photos.  It all helps when you go to re-assemble even if just for routing of hoses/wires/etc.
While you're at it (if not done prior) replace EVERY cooling system hose under the inlet manifold.  Use genuine if you can afford it.  Also replace all vaccum hoses especially the ones that run around the back of the head for the waste gate actuators.  after 20+ years they all go hard and can crack.  Being where they are located you don't find out till it's too late!
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804586
Oh, man, if you want a list of all the things you should replace when you have taken that much of the engine apart, it includes (but is certainly not limited to!)
  • All gaskets.  Obviously enough, but people do sometimes expect to be able to reuse turbo and dump gaskets and so on, and if they are older than a very short time, it's better to replace.
  • The heater hoses that connect the engine to the firewall.  They are well old now too.  They probably fall under the category mentioned by Shoota above.
  • The timing belt, obviously enough, unless you know that it is recently replaced.
  • The water pump.  Thermostat.  Radiator hoses if they don't feel fresh.
  • Head studs.  Prime time to put ARP ones in.
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804588
On 13/01/2017 at 5:32 PM, 89CAL said:
Its been a while but arent there some plugs up around that area? I assumed they were for coolant but could be wrong. Worth pulling the whole coil pack assembly off i would think if you havent already done so.
Also, its easier to undo the 5 bolts that hold the coil pack brackets in place to do plugs than to pull each individual coil pack off. If it helps :)
That was the plug I was talking about. I think there are a few along the top of the head. Wouldnt hurt to pull all the coilpacks out and check. They may be for oil though. I'm not 100% sure
Edited by 89CAL
Extra Info
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804775
Update: I did a compression test and a block test to see if any exhaust was in the coolant system.
Block test: Negative
Compression Results: each cylinder was done 3 times and the engine was warm. I did not have the throttle wide open during the test.
1. 160
2. 160
3. 160
4. 160
5. 160
6. 152
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7806654
  • 4 weeks later...
So here's an update: I'm saving up money to purchase a new head from TOMEI so in the meanwhile I used JB Weld to fill the hairline crack in my head. It has been 3 weeks and not a drop of coolant has leaked from the where the hairline crack was. I was very iffy about using JB Weld on my cylinder head but to-date it has worked wonderfully.
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7811788
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
