This article lists it as street legal in Australia: http://www.ozzytyres.com.au/blog/the-nitto-nt-performance-and-invo-tyre-range/
Also Toyo refers to the R888 as street legal on their site, it's the same compound as NT01 (though different tread pattern): http://toyotires.com.au/tyres/motorsport-tyres/item/20-proxes-r888
Neither is really a street tyre though, my R888R's are super noisy at freeway speeds and wear a lot faster than my KU36's. Also they pick up a lot of debris from the street because of the soft compound, so I certainly wouldn't run them as the primary tyre on a street or mixed use car.
https://www.sau.com.au/forums/topic/468607-nitto-nt01/#findComment-7804564
3 minutes ago, Subi001 said:
I ment I don't want to have 2 sets of wheels.
It will be cheaper to have 2 sets of wheels if you plan to do a lot of track time.
I had a set of Bridgestone semis which were great on the track but not good on the road so I sold them.. I got a second set of wheels at relatively low cost and got second hand slicks from the NZV8 series - they get rid of them when they drop off half a second per lap but are fine for track days. If you have quality track tyres then you will just waste them driving on the street (plus they will be marginal after a few km and in the wet).
If you are determined to have one set only then you have to favour street use and put up with less than optimum track times.
https://www.sau.com.au/forums/topic/468607-nitto-nt01/#findComment-7804650
Want my car to be street driven and for track too. Want to spend money once on the tyres
It you really want to run a single set only get AD08R or similar. Not as hardcore as the NT01 but also unlike them actually good for both street and track.
Otherwise a dedicated second set of rims and tyres or the track would be a good call.
https://www.sau.com.au/forums/topic/468607-nitto-nt01/#findComment-7804662
if you're serious about doing any track time then another set of rims/wheels will be needed. Great for track ain't great for street. Or as above, AD08R, but won't last long on street so cheaper to hav a 2nd set, in the long run.
  • Like 1
https://www.sau.com.au/forums/topic/468607-nitto-nt01/#findComment-7804675
I run 315/30/18 nt01's on my rear and 265/35/18 advan ad08r's on my front and it's a winning combo for street and track and also has been suprisingly grippy and drivable in the wet... But yes the rears do pickup a lot of small rocks etc. but for the level of grip I'm now getting it doesn't bother me.
IMG_1484440065.535818.jpg.4d218c68452254
https://www.sau.com.au/forums/topic/468607-nitto-nt01/#findComment-7804786
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
