No. Firstly the gear ratio is different. You may be able to take the ratios from your 33 diff to fit into the 34 diff.
But there are other complexities with replacing a 33 vspec diff, I'm not sure of the details maybe try a search around. 33 vspec have some whiz bang active diff with lots of bits that make it work....
  • Like 1
It's a bloody shame no one has come up with a solution for putting an LSD centre into the A-LSD housing. Surely with Nissans level of interchangeability between models there's something that fits. Someone like Award could possibly come up with a solution. Otherwise there's going to be a shit load of A-LSD's laying around rotting once they've all been swapped out!
1 hour ago, DJBarnstar said:
Thanks Team, Yep it would shag the ratio in the 5 speed. Forgot about that.
I'll just have to go the route of replacing the shafts and putting a non-vspec with a 1.5 in.
Cheers.
I have a 3.54 front diff if you want to try swapping the rears.
Nice one!!
I must be the only person considering putting an A-LSD into a Skyline. Street car GT four though, I'm currently suffering with a viscous lsd...
Seriously though, they are just a clutch pack LSD, actuated via computer controlled hydraulic pressure. I'm wondering what it is that causes them to go bad. I have read that they don't like too much heat, and over 350kw they would appear problematic, but I'm unlikely to test that limit.
One interesting thing i read, they lock more with increasing lateral g, which seems sensible. However- if you have installed an ATTESA controller, typically these reduce the lateral signal, to get more front drive, but as you can see this would reduce lsd lock at the same time. I'm fascinated by the computer control, so hopefully I'll try it one day! On the lookout for cheap R34 v-spec attesa pro ecu's :)
5 minutes ago, dr phil said:
Nice one!!
You make it sound so simple! But a mechanical LSD is even more simple.
If one had a car with the A-LSD it would certainly be worth trying to give it a good service before giving up on it. There is a piece on how to do that at the top of this section...but it seems a little OTT to install one (instead of a mechanical LSD) when there is not one there!
Installing a mech lsd was certainly my first plan, and yes understand it is a lot simpler. But then i read a few posts recently about them being a pain around town, needing to clutch-in around tight corners etc. perhaps i just need to find a loose one.
  • 1 year later...
Never mind what a few posters say. GTRs come standard with a mechanical LSD and I put one in my Stagea and there was no "putting the clutch in to turn tight corners" nonsense nor was it at all harsh. Some brand new aftermarket LSDs need a little running in but that would be nothing compared to the headache of trying to install a V-spec LSD. oops advice a year late I see:blink:
  • Like 2
I have a V Spec R33 and right now I'm trying to sort an Attesa problem and which also is only letting the left rear tire get traction
If you are spinning the rear right tyre too much then it sounds like your A-LSD isnt locking up properly, so try bleeding it on top of the diff for a start. If it’s always biased to one wheel, maybe check if one of the brakes is dragging too. Got any warning lights on the dash?
When i got my GT Four I bled the attessa fluid and it was thick like old engine oil, yuck. Replaced with Transmax Z.
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
