looking to buy r32 gtr but prices are crazy now?
so i am currently in the market for an r32 gtr. but the prices now days are crazy, i remember looking a few years ago and they were like 15k now simillar ones are 30k+
do you guys think the price will continue to rise?
Here is an average 3.5 graded car that just sold for 2020000 yen.
http://www.exportcar.jp/en/component/auctstat/?view=auctstatdetail&id=lwZh82xpiDCHJX6
Landed, complied and registered with stamp duty paid is just under A$37K.
18 months ago I sold a lovely gun metal grey car similar (but probably slightly better) to this car for $25K.
Same car today $40K+.
Times they are a changing!
Bob.
  • Like 2
This is the crap people on facebook are trying to spread regarding the prices of imports vs domestic cars
"Looking at recent jap auction results for R32 GTRs, you could pick one up for $25 to $30k landed and complied. This is for grade 3.5 with around 100 to 150kms.
Thought this might be useful for those wanting to get one cheaper than getting one locally and you know the kms are genuine.
Cheers"
This was my response:
" Not sure where you are seeing that, got some example links? All i'm seeing are 3.5-4's which are either or both wound back/no books and are still going for 17k USD which is around 2.1million yen. Obvs the ones which have both books and kms genuine are much higher. Which after compliance goes well over 30k landed and complied. Not even including rego etc"
I think it just depends what's around at the time.
Sometimes you are a lot better buying locally, other times importing may be the better option.
The trick is to understand how the Japanese gradings work so when you look at a car locally you can say its a 3 or 3.5 or 4 etc.
Once you know that you simply compare it similar cars in colour, milage and condition.
Download this - http://prestigemotorsport.com.au/cost-calculators/
Search here - http://www.exportcar.jp/en/component/auctstat/?maker_id=2&model_id=330&year_from=1989&year_to=1994&engine_from=2600&engine_to=2700&transmission=&shift=&mileage_from=&mileage_to=&auction=&lot=&gradings=***%2C1%2C2%2C3%2C3.5%2C4%2C4.5%2C5%2CR%2CRA%2CS&mode=statsearch&sort_field=&sort_order=&limit=20&view=auctstat
Armed with both websites you can be an informed buyer.
Cheer, Bob.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
