  • 4 weeks later...
I was hoping Sauber would go back to the jellybean mags of a few years ago :(
New cars look good though - the lower, wider rear wing totally transforms them. Not liking any of the liveries other than Williams yet... Too much fussy gold on the Sauber. Too much black on the Renault which hides the car's shape. And Ferrari's are supposed to be red.
Keen as for the racing to start - Pirelli reckon they'e actually made tyres not designed to degrade so they can actually drive them hard in the race, and corner speeds should be pretty epic. Hopefully that's right and the fast drivers get some reward from it, instead of it being all about tyre management.
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812792
FB_IMG_1487671484944.jpeg.57a65db47b03eb5c59373f2b4faf090c.jpeg hoping this isn't final... Too much white for my liking
I believe Ferrari said they were going back to the old days and were going to get rid of all the white
Or maybe that was black they were getting rid of....... pretty sure white
I actually like the new sauber. I think it just needs a major sponsor. Sidepod looks a bit bare
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812807
Fingers crossed...
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812811
That STR is quite blingy...
also how does everyone feel about the Shark fins? I liked them when they had them years ago and I still do, well some of them... some look shit, usually the ones that are squared off at the back, cant remember which team has it
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7813624
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
