2001 STAGEA COMPLETE CAR ALL PARTS AVAILABLE
WILL PART OUT ALL PARTS, CONTACT TO GET A PRICE FOR WHAT YOU NEED.
01 Nissan stagea, Turbo 4wd 5 speed tipronic auto. Car is an unfinished project has been sitting for a while, has never been in an accident, not a repairable write off. Doors and tailgate had dents in them have been replaced but unpainted.
Engine has Arp headstuds, Cometic head gasket, all seals, water pump and water pump replaced 10,000 kms before coming off road. Turbo is not available. Vehicle had brembo calipers but have been removed. Rotors to suit the brembo are still on vehicle. Has a 600x300x125 inter cooler kit with stainless piping. Original xenon headlamps. 18inch alloy wheels
CAN ARRANGE FOR IT TO BE TOWED TO BRISBANE IF REQUIRED
CALL 0468698581
  • 4 months later...
  • 4 months later...
what number ECU is in the car please and how much ?
I am after one with the following numbers: 23740-0V811
  • 3 months later...
Hi there Ben,
I have rusted front turret tops on my Stagea that I need replacement panels for.
Do you still have yours in the car, and would you like to part with them??
Regards,
Martin
  • 1 month later...
  • 4 months later...
  • 3 years later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
