V35 automatic transmission problem
Hi, Ive had my 350 GT coupe for a couple of year and its been pretty smooth sailing. However, I recently had an issue when I was driving home from work on xmas eve. As I was exiting a roundabout, I heard (moreso felt?) a thunk from the automatic transmission. The car would free-rev until about 4000rpm, then would throw you back into the seat with explosive acceleration. I pulled over and shut the car off for about 30 seconds.
 When I started ot up again, the AT check light was flashing at me like a maniac for a few seconds before switching off. I was able to drive home without any problems. A few days later, it did the same thing, however it happened when reversing out of a parking space and engaging drive. This time, there was no noise and the low down throttle response was better.
Online investigation on G35 driver etc indicates the car is locking 3rd gear as some sort of limp mode. This problem has come on suddenly, and the transmission works fine during regular use. Tiptronic mode works fine- the problem only now seems to happen when engaging drive. The AT light flashes a total of 16 times. From what Ive read, this particular error code is not logged in the ecu,  therefore a diagnostic is useless.
I had the transmission fluid replaced about 9 months ago as I am the first Aus owner of the car and didnt know when it was last done. When replaced, the old fluid was still really good. A few topics on G35  driver where people have had the same issue advised a transmission service, including changing the filter, fixed the issue. There has been a slight whine from the transmission when the car is first started in the morning- it sounds like someone using a whipper snipper at the end of the street, and fades in and out. This noise disappears after about 30 seconds and is very quiet. I have tried to record it, but cannot be heard when played back.
Long story short- has anyone experienced a similar issue? I dont have the money to fork out hundreds, if not thousands, of dollars trying to diagnose what the issue could be. So far, it could be a service issue,  a faulty sensor, some sort of pump in the tranny is on it's way out, or my transmission is outright stuffed (I don't think it is due to the way it drives and shifts). Any help or suggestions would be appreciated.
https://www.sau.com.au/forums/topic/468693-v35-automatic-transmission-problem/
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
