Those relays control all the ACC and IGN circuits that run through the fuse box, they are triggered by the key turning.
Is there some problem you are trying to track down?
BTW everything there looks super neat, clean and unmolested....nice buy!
Thanks!  I got lucky, my car was an unmolested one owner car in Japan for 24 years, which is rare by R32 standards.
I am just trying to find the turn indicator relay.  Bought some Sylvania Zevo LEDs, but I don't want to splice in resistors.
The turn flasher is on the left of the steering column near the clutch, its a black box with an orange (from memory) mount.
If it's no longer right hand drive, it could be anywhere! But it's not part of the fuse box on a 32
Thank you for the info!  My car is still all factory so I am positive the relay is at its original location.
Turn indicators on and feel for the one clicking on and off. Thats how i found mine
All my lights (except headlights) are LED. Just bought a non load dependant flasher and wired it in for the indicators. Works a treat
Found a 9 year old post on GTR UK forum - the indicator relay is a black box with a white label on it under the steering column.  A picture was provided, but it no longer loads with the post being so old.
Which specific relays did you get?  I see some fairly cheap LED relays on eBay shaped like factory relay, so supposedly they are plug and play, no wiring needed.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
