Suitable wheel sizes for R32 GTR
Hi All,
I'm interested in purchasing Volk Racing CE28N however not to sure where to buy them from and roughly what they going for, does anyone have an idea? also I want 18 inch but will I have any problems with the guards? or the callipers (standard).
after looking online I was thinking 18x10.5+18 5-114.3 with 265/35 tyres.
does anyone think these will be too big or is it possible? without loosing the handling
RAYS VOLK RACING CE28N 18 x 10.5 +18 5-114.3 BRONZE
https://www.sau.com.au/forums/topic/468713-suitable-wheel-sizes-for-r32-gtr/
Rays list them at 82,000 yen each.
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=CE28N10
So that plus freight.
Where from? Start with the likes of RHD Japan, Nengun and then move on to Jess Streeter.
You are looking at over $1000 per rim and they wont fit properly.
The problem with the sticky thread is that how ever well meaning it started out it is now inhabited and infected by the hektik fitment types.  In the olden days the universal aftermarket rim size on an R32 GTR was 17x9+22.  Which just about fits but often as not scraped on the rear.  Now it is apparently 20x11.5+0 with 10 dergees camber to make it fit and no way of applying more than 3 degrees lock.  Hektik in other words.
  • Like 1
  On 20/01/2017 at 3:09 AM, niZmO_Man said:
For a 265 wide tyre, get the 9.5" wide wheel. 10.5 is too wide for the R32.
Thanks mate. Currently i have 9.5's. I thought i might be able to go bigger but now i dont want to take the risk
  • Like 1
FWIW i'm running 18x10.5 +25s wearing 265/35s on my BNR32. Rear guards are rolled and the front rubbed with unmodified guard liners.
The tyre manufacturer data I looked at confirmed that 265 is a suitable fitment on 10.5in rims, but every tyre is different so check the specific tyre you're considering before you buy it.
im also running 10.5 +22 rears and 9.5 +15 fronts both with 265-35-18 no modification on my stock bnr32.
im not running hellaflush stance though
DSC_0413_zpskekzoqhd.jpg&key=36089733fef
Edited by GH05T
  • Like 2
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
