Jonnodawg Posted January 18, 2017 Share Posted January 18, 2017 V35 350GT Skyline - Engine missing and No power at high revs Hi Guys, I've got a 2003 V35 350 GT Skyline and I've been having an ongoing issue with engine missing and then no power at high revs. It only seems to be after I've been running the car for a while or at the end of a trip home from work (about a 30 minute commute). I've taken my car to a mechanic a while back when I was getting a service, the missing happened at that stage while idle but it didnt seem to effect the power from the car. It had gotten a lot worse and took it back to the mechanic and they claimed it was an iginition coil. They replaced it, drove it to work in the morning no problems. Then on the way home I when I first started driving, it wasnt too bad, maybe a rough idle at times. Towards the end of my trip I tried giving it a bit of power and it as soon as it went over 4k revs it just loses it's power. I've gone to this same mechanic in Brisbane for years but I always seem to have issues where I have to come back to look at things so I may have to look at going to someone else. Does anyone know what this kind of issue sounds like? Thanks in advance, Jonno Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/ Share on other sites More sharing options...
Wayne Sotanned Posted January 19, 2017 Share Posted January 19, 2017 I suggest you take it back to the mechanic and have him check whether 1. There is any oil leak into the sparkplug chamber 2. Engine Compression for any leak, if there is then an engine rebuild is required which might cost thousands. In my case my mechanic is able to fix it with a few hundreds without having to rebuild and my car still performs well. Is there any stutter with the rev during idle? Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/#findComment-7805777 Share on other sites More sharing options...
Jonnodawg Posted January 23, 2017 Author Share Posted January 23, 2017 Sorry for the late reply! Haven't been able to get back on yet. Yes it has a rough idle, but this is where it's weird. If it's cold there is usually no issue but give it about 10-15 mins of driving, when I pull up to a set of lights I get a very rough idle.But this is when the car is in drive, once I put it into neutral it stops happening, or significantly less then when in drive. Who is your mechanic? It would be great to get in contact with him. Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/#findComment-7806468 Share on other sites More sharing options...
Wayne Sotanned Posted February 6, 2017 Share Posted February 6, 2017 I think there might be something wrong with the Camshaft/CrankShaft sensor as well and it is a factory-recall reported issue for our car model. My mechanic managed to narrow it down to which one specifically and my car has been running fine since then. He is based in Bankstown. I'll inbox you the full address if you are still interested Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/#findComment-7809402 Share on other sites More sharing options...
Wayne Sotanned Posted February 6, 2017 Share Posted February 6, 2017 FYI, rough idle usually can be fixed by cleaning the Throttle Body and performing idle relearn procedure. Then after doing all that and the issue is still there then the Cam/Crank shaft sensors are next to be looked at. My mechanic and I went through the whole eliminating process to narrow down the root cause. Hope that helps. Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/#findComment-7809451 Share on other sites More sharing options...
mutex Posted February 12, 2017 Share Posted February 12, 2017 First thing I'd do is get a code reader to check for any error codes. Workshop or ebay. Link to comment https://www.sau.com.au/forums/topic/468714-v35-350gt-skyline-engine-missing-and-no-power-at-high-revs/#findComment-7810682 Share on other sites More sharing options...
