Thickest Oil for gearbox ??
Hey Guys and Girls,
so a little bit ago, i had the clutch replaced in my R34, since i got it back from the mechanic the gearbox has felt more clunky (changing to second when its cold sometimes is really hard, just feels like i can feel the gears clunking together). not sure as to what rating oil he has put in gearbox, so i want to change it to something i know is thicker.
what is the thickest oil ? or what oil would you recommend i put in it.
https://www.sau.com.au/forums/topic/468718-thickest-oil-for-gearbox/
55 minutes ago, GTSBoy said:
Are you sure that you need thicker oil to solve this problem?
Yeah i think the thicker oil is going to make the box feel a little bit better for the mean time until i can get around to getting it rebuilt, a rebuild is gonna cost me at least 2k or more maybe. so in the mean time i was thinking thicker oil to make it feel a bit better and maybe damage it less ?? cause i can feel like the cogs hitting each other and i dont think that can be good for it.
57 minutes ago, Hadouken said:
Gtt or gtr?
Maybe you should ask him what he used. If your oil is to think then it will feel shit while the box is cold.
GTT, i will give him a phone call and ask him, before the clutch being replaced the gearbox didn't feel as bad as it does now. so im guessing the new oil is a bit thinner then the old oil.
I live in orange so winter is rather cold here, and if the box is a pain while cold in summer then i am guessing its going to be worse in winter here.
6 minutes ago, Hadouken said:
If you put thicker oil in your box will suffer even worse when cold!
Feeling the synchros is not a issue. If it's making noises then it's an issue.
Put redline in it if you think it needs a rebuild
Yeah i can feel the synchros, not making any bad noises tho, if i roll along in 3rd it seems like it is going to pop out of gear.
so avoid thicker oil then, shall do.
redline lightweight shockproof ??
also cheers for the advice :)
It may also simply be a clutch adjustment problem. I'd suggest talking to your mechanic to see what they think too. Depending on the exact clutch and pressure plate, and how your pedal is adjusted it could either be a pedal adjustment or thrust bearing carrier length issue.
And also ask exactly what oil they put in, and perhaps check the oil level (open the filler and see if you can touch fluid when you stick your finger in there).
Its very unlikely your gearbox suddenly developed an issue the day the clutch was changed....
  • Like 1
I will check the oil level and go from there, and also ask him what oil he put in it.
i don't think it suddenly developed it, i think maybe the different oil made it feel bad and clunky, if that is possible ??
56 minutes ago, Dobz said:
^^ I agree with Duncan. Do you have to push the clutch solid to the floor to disengage it or change gears?
no the clutch disengages at top
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
