R35 GTR Brakes onto at R34 GTR. Who's done it?
Hey Guys,
I'm looking to upgrade the factory 34 GTR brakes.  Currently i'm looking at fitting a full set of R35 brakes and i wanted to know;
*If anyone on SAU has done it?
*Did they have issues with the brake bias between the front and rear and if so how was it solved?
*Is any modification required to make factory handbrake work with the R35 brakes?
*Who did they get they get to make the mounting brackets (preferably in NSW)?
thanks in advance.
I haven't done it but know that there are no issues with brake bias (even on track duties) since you already have the BM-57 Brake master Cylinder on the R34..
You may have to modify the backing plate on the rear that i've highlighted in the attached picture.. Otherwise you won't be able to physically fit the larger rear disc..
The rear handbrake issue is solved in 2 ways depending on which kit you buy and from who...
One is the rear rings that are press fitted into the rear of the bell10666034_818413308189102_5230253162384342326_n.jpg
The other option is to have the complete rear bell which are normally sold as part of the adaptor kit.. (Old picture) But you get the idea..
New version from Supertec Racing..
I have done the kit on my s3 R33 Gtr and I also have a spare set of billet adaptors to suit, no problems with brake bias and don't need to upgrade the master, backing plates need to be cut to suit to fit bigger caliper.
  • Like 1
Can you provide us with some brake porn sir?
  • 9 months later...
PM'ing
  • 2 years later...
N
On 25/09/2020 at 9:05 PM, Paparazzi said:
Will the conversion fit behind the oem r34 wheels?
no, there are only a few wheel options that will work with 18s and they are the volk racing or rays gtc, ze40, te37s.
    • Shove more foam in it as a minimum if you possibly can. Or steel wool (not the stuff with soap on it!) Baffles / getting the oil out of the air is huge, and should be done at both the cam cover, and the catch can.   I'm about to do a power steering reservoir, and even that needs some thought to make sure air is separated from the oil, to stop evil Cavitation. I'll probably look at doing my own catchcan later on too.
    • I was once told, who it was I'm to old to remember, that the length of the OEM wheels brace supplied with a vehicle is designed long enough for a average person to apply enough torque to do up, and undo the wheel nuts to the specified torque  What a average person is is anyone's guess though, i.e. average fat bastard, average knuckle head, average perfect sized human......like me Unless of course, a tyre shop has ugga dugga'd them up to "torque to yeild/strip" specs, used cross threading as natures lock tight, or a big breaker bar was used to tighten them up to get some nice stretch in the poor old wheel studs Me, I torque wheel nuts to 1 elbow joint click, lower torque settings are based of wrist clicks, higher torque settings are based of shoulder clunks, or total dislocation for anything that requires all of the torques
    • I think the catch can design is pretty flawed. Evident in the fact that the V2 one moved to a larger top mounted filter which alone would have helped with overflow and reduce restrictions compared with the side filter. I also imagine there was a major improvement to the baffling design. It is worth mentioning that this catch can with the RB20 was never as much of an issue and the high kms RB25 is likely a part of the problem. I have gotten quotes for both a new "Vibrant Gen 3" catch can and to modify this existing ones but that may have to wait until after the track day. I hope the sump/head breathers/drains and cam splash plates will be enough
    • Yep, both. The ratio is 1.8 instead of OEM being 1.7. The rocker bodies are modified with a larger bolt hole and re-threaded with 10mm holes instead of the 8mm YT has stock. Finding out they don't actually fit the stock castings cause a lot of un-impressment by the person in the USA who tapped the new holes for the 'upgraded' YT product. He was very unhappy with them given their previous design did not require 'clearancing'
    • That too, but I think this is why she's put the work into the cam cover baffles. I mean, a catch can should only need to be a catch can, not an oil air separator also. Not to say that putting the effort into having it do a better job of oil-air sep is a waste of time, but doing the sep earlier is always going to make life better. And that should happen now anyway.
