Hi guys
R33 rb25det s1
I just changed my intercooler from a 580x28×68 not sure on brand as i got it with car to a HDI gt2 600x300x80 and went back for tune and lost 400rpm in response/full boost
Power with before intercooler was 341rwk and power with hdi gt2 intercooler made 360rwk
Before would hit 20psi at 3800 rpm now 4200rpm with just intercooler swap nothing else no piping changed nothing/still same length and size
(Hypergear gear ss2/external gate/e85)
Boost level on before intercooler was 20.5psi and boost on intercooler hdi gt2 22psi
Would see Full boost in first gear with before intercooler and now cant even make more then 12-13 psi in first on hdi gt2
Could it be the intercooler to big or just cheap chinese intercooler compared to before
Any help would be great
Sorry wrong thread
Edited by RamR33
https://www.sau.com.au/forums/topic/468730-r33gtst-intercooler-problem/
Extra 20KW would suggest its a better intercooler. How much time was spent on the tune? It would be quite different with that much more air.
Don't think you would want full boost in 1st.
I had similar issues when I had a front end smash and put a cheap fmic on until I could afford to go back to the blitz fmic I had previously before the accident
long story short after a dyno run I went and got the blitz one straight away because the cheapy was not doing me any favours whatsoever
+1 for that bro
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
