6 hours ago, TXSquirrel said:
Is Greddy or HPI intercooler no good?  With shipping to the States, they will cost less than Plazmaman for me.
My car has a HPI Aluminium Radiator. It did the job on a super hot tack day (38 degrees).
I can't comment too much, but it seems to do the job. You should probably value the opinions of the others over me though... they've been around a while longer than me.
  • Like 1
18 minutes ago, Hadouken said:
^^ especially, seeing as the topic is intercoolers...
Damn it! Well, i proved my own point, i guess.
I don't know what intercooler I have, guess i will have something to look at tonight.
Edit: ok, having acheived peak stupid today, i'm going to log off and go have a nap.
Edited by Steve85
  • Like 1
I am reading this post because my bnr32 is having high IAT issue.
During normal driving when ambient temp is below 30C°, my coolant temp would stay between 75C°-80C° as I have Nismo's lower temp thermostat.  However the IAT is consistently showing above 50C°.  If I'm idling for a while in stop-go traffic, the IAT would creep pass 55C° while coolant still staying below 80C°.
Is that normal?  Is my factory intercooler not working properly?  Or there are other issues at play?  I figure it couldn't be the fan or fan clutch because coolant temp reads just fine.
Car is still all factory, down to the air box.
The IAT sensor currently in the car is a brand new Nissan OEM.  My first thought was a bad sensor so I bought a new one, but reading is the same.
The new sensor looks completely different tho, it's a much thinner rod and the plug is blue instead of yellow.  To make sure I got the correct part I even tested both new and old sensors in hot water to see if the ohm readings are in range, which is probably what I should have done before I went and bought a new one...
I also notice my car smells quite rich, but I'm not sure if it's because I have a straight pipe or the ECU is compensating for high IAT readings.  However as far as I can tell the lambda readings off the factory narrow band are normal.  Unless the Greddy Infometer I'm using is getting every reading wrong...?
So your readings are coming from the Infometer?
You said that you checked the sensor using water before - could be worthwhile checking the resistance output of the sensor using a multimeter hooked up during running to confirm that its not the Greddy being a bit optimistic.
Are you using a stock ECU?
Edited by baron_von_bootsector
forgot the ecu question
He already checked the resistance he said.
Where abouts is the sensor located.
If the Greddy is the only way you can read that data, my guess is the calibration is wrong.
The car would drive like shit with 50deg intake temps/
Yep thats what I was getting at, check the output of the sensor while its on the road to confirm the Greddy is not the issue. A few feet of wire and some alligator clips and you are set.
Everything is stock in the engine bay and so is the ECU.  The IAT sensor is still at its factory location on intake plenum, at the kink before first throttle body.
Infometer is pretty much a plug-n-play off factory consult port, only the AFM and O2 voltage can be adjusted/calibrated.
I have swapped around the sensors a couple times with the factory radiator one and a 2nd new OEM one (yeah I bought another one just to be triple sure :(), same result...
At least car doesn't drive like shit, I think... well, this is the only bnr32 I have ever driven...  So I do hope Infometer is showing false readings, because I don't want to drop $650 USD for a new intercooler when the factory unit is working fine.
Factory core good for 300rwkw+ without issue at all.
Might be time to extend/alligator clips and do some more testing in other locations/outside engine bay etc.
Any Nissan dealerships around you/import shops that might have a proper consult so you can get a readout from the ECU?
You cold also buy a consult cable and use ECUTalk (which I think was free).
The RB26 IAT sensor is not really doing a good job of measuring the air temperature.  It really reflects the plenum temperature, which is often a lot hotter than the air.  For this reason, the RB26 ECU doesn't look at the IAT for any normal fuel-air or timing input.  It's really only there for the ECU to go into a panic if it get seriously hot.
So before getting too worried about the IAT sensor, the infometer, or anything else, I'd suggest slipping a skinny wired thermocouple bead under a hose clamp after the intercooler and try to measure the air temperature more directly.  Or install a proper IAT if you want to go banzai on it.
Without wishing to go OT, how is it that the RB26 IAT sensor measures plenum temp rather than air temp? Doesn't that suggest that no matter where and IAT it is it'll measure the temp of the thing in which it's sitting rather than the air? What does the RB26 ECU use for normal fuel-air or timing input?
Because it hardly protrudes into the airflow at all and isn't insulated from the plenum at all so just heart soaks as the plenum temp increases. Yes it will rise with IAT but won't be very responsive at all. ECU will use AFM, O2, Knock and coolant temp to calculate fuel injection from memory.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
