RB_purr Posted January 20, 2017 Share Posted January 20, 2017 R33 actuator issues Hey guys I'm having issues with my actuator on my 33 it keeps getting stuck open it never used to have this issue and I haven't changed anything for this problem to arise i can only assume its just seen better days even if I move it by hand it get stuck open halfway.. It's the stock RB25 actuator and I'm running 14psi with a boost tee on the stock turbo would i be best to settle for a 14psi actuator from turbosmart considering that's the set boost level that I always use ? i have heard some people use a lower psi actuator but run higher boost which I can't quite understand but would I be right in saying that a 14 psi actuator for a 14psi boost level be better suited for my application? Just wanted to check in with other members before I go spending the money Cheers Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/ Share on other sites More sharing options...
89CAL Posted January 20, 2017 Share Posted January 20, 2017 Its better to run an actuator with a lower spring pressure then your target boost and get their with a boost controller, it means the boost comes on a little stronger Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806019 Share on other sites More sharing options...
RB_purr Posted January 20, 2017 Author Share Posted January 20, 2017 2 minutes ago, 89CAL said: Its better to run an actuator with a lower spring pressure then your target boost and get their with a boost controller, it means the boost comes on a little stronger So would I be better off settling with an RB20 actuator? Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806021 Share on other sites More sharing options...
89CAL Posted January 20, 2017 Share Posted January 20, 2017 Have you checked the rod and flap? Remove the rod from the arm that controls the flap and see if the flap moves freely. Check that there is some pre-load on the actuator. If the flap moves fine then no harm in replacing the actuator Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806024 Share on other sites More sharing options...
RB_purr Posted January 20, 2017 Author Share Posted January 20, 2017 (edited) 5 minutes ago, 89CAL said: Have you checked the rod and flap? Remove the rod from the arm that controls the flap and see if the flap moves freely. Check that there is some pre-load on the actuator. If the flap moves fine then no harm in replacing the actuator Nah it's not moving as freely as it should but there is some preload what actuator would be the best option to go with you think ? Edited January 20, 2017 by RB_purr Dribble Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806026 Share on other sites More sharing options...
admS15 Posted January 20, 2017 Share Posted January 20, 2017 If the flap isn't moving freely, an actuator isn't going to fix your problem. As I stated in your other thread about this, you can try freeing it up by spraying wd40 or equivalent on it and working it loose or remove the turbo and have the wastegate looked at by a professional. 1 Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806047 Share on other sites More sharing options...
89CAL Posted January 21, 2017 Share Posted January 21, 2017 As above, the flap should move freely, if it doesnt Id be starting there Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806139 Share on other sites More sharing options...
GTSBoy Posted January 21, 2017 Share Posted January 21, 2017 Why do they all insist on skipping the step where they take the problem thing apart and work out what is wrong themselves? Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806148 Share on other sites More sharing options...
admS15 Posted January 21, 2017 Share Posted January 21, 2017 Kids these days.... Link to comment https://www.sau.com.au/forums/topic/468736-r33-actuator-issues/#findComment-7806156 Share on other sites More sharing options...
