Upgrading to single setup, need some help
Hey guys,
Im pretty new to this but have done some reading. I have an r33gtr vspec & just chasing approximately 450-500hp and dont want to touch bottom end. Do i need to upgrade my camshafts? or anything else along the way for the power im chasing. If so what is recommended that wont send me broke as i have already purchased a few items already, atm i have purchased a single turbo kit setup; (6boost manifold, 6262 precision turbo 0.84 rear, twin scroll t4 with the turbosmart prolite50mm waste gate.)  Also purchased 1150cc (e85) injectors & 460LPH walbro pump.
Just purchased a timing belt kit also, with water pump inlcuded (hence why im asking about camshaft before replacing. )
Already have Power fc that was installed and tuned with old setup which was the N1 twins.
Would be greatly appreciated with all the help i can get with info.
Good news, just remembered that previous owner has replaced the head gasket :D So i guess last thing that i shall do while i do the timing belt kit is the cam shaft, will go for the typeB poncam from Tomei
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
