Hi guy's just wanted to to find out what types of protection systems people are using to protect their pride.
I can think of :
House alarm
House camera's
Car alarm
Wheel clamp
Steering lock
Gps tracker.
So ATM i have Hikvision cameras 4mp got the entire home covered i upgraded one of the camera for up to 70mtrs of night vision down the long driveway got the professional installation of it.
Can view live from anywhere in the world.
Basically if the airport using them its good enough for me. Image is so good i rekon ill see a mouse run from about 35mtrs away.
Home_34_20170112095908919.thumb.jpeg.02d
As for house alarm sensors are in garage too im using bosch.
Now i do i have a car alarm i think its autowatch. Have not played with it much seems to be ok
I thinking of using a steering wheel lock old school should I ... .?
Is anyone using a gps tracker and remote kill switch ?
ive heard of them but very spectacle of it.
Now if it not a daily wheel clamp it ?
Or too much damage for a sexy LMGT1
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/
Damn that's a good quality camera.
Got generic cameras around the house. I disconnect the battery and take the steering wheel off (quick release).
You can also disconnect/remove an AFM/the ECU/kill switch, but if someone wants your car, they'll pull it up onto a flat bed.
Don't clamp the LMGT1s please :P
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7806414
Oh ok remove the steering wheel awesome idea.
I have a Daikei steering wheel boss is that a quick release.?
Thank you yes they are great camera's its actually a bit more then 1080hd
With the kill switch i was thinking like calling the car and it just dies on them then i get gps location and boooom got em.
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7806510
Found this car tracker aussie guy that imports n sells em
Just wanted to know if anyone using it coz apparently he sell them to big companies and most rental car company.
It even features a kill option so positive wire on relay connect to fuel pump or whatever triggered by sms
Only thing i want to find out is how good is the reception ? Using telstra.
And did anyone test the kill switch ?
Product looks promising.
http://www.ebay.com.au/itm/262745785716
1485508299667.thumb.jpg.3cc31cb960dcf3e6
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7807357
Sounds good for the price
The concern I can see just quickly looking at it is that there is no integrated GPS, so Im gatherithing its using multiple mobile phone base stations (normally 2, lucky 3) that triangulate on sim signal to indicate estimated location. This fails in accuracy for a number of reasons when something valuable is at stake, but I guess u can add a gps in the port but then price/value changes
Edited by Watermouse
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7807360
Found another idea that is super simple and makes it just that little bit harder.
If your car is lucky as mine with its own personal garage.
Switching the power off is great in my mind.
Got the idea coz when i was a kid i used too ride on my bike changing my remote codes and use to open peoples doors haha hope it won't bite me in de ass now !!
1485914449598.thumb.jpeg.65c1d850b46b44e
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7808237
  • 1 month later...
my bad, only have blue tooth range
Oh I've seen them pop up on Facebook a few times i looked into them and found that one brand sync with a wifi network and makes a wifi networking range with other key finders so it has a bigger range downside to this is that 1 has to the wifi connected or Bluetooth 2 needs other finder to make a network for longer range 3 makes drop point location not gps location on demand [emoji20]
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7819403
I recently installed the tracker thats listed above that i got from ebay aussie guy and even call him to get more information before i paid 4 it.
I must say that I'm very happy with the product once i activated my simcard installed the tracker nice and deep ( what a pain is the r33 dash !!! anyway ) connected the 12V+ Ground- and Accessories and log on to my account online very easy must say very accurate too the dam thing know what side my car is sitting in the garage. [emoji12]
Also came with a relay for a fuel cut out by sms will update on how it work well once i get around to it.
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7819413
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
