Post up what you'd like to achieve (and the budget!) and we can offer some advice.
Try to set out what you want to do with the car and set a reasonable / specific goal for what you want to achieve - what you need to do / buy then flows from that.
Trex is on the money, read up on some of the other build threads or dyno results threads under "Forced Induction Performance" to see what others have done and it will prove invaluable to see what needs to be done and gives you an idea of the sort of costs / parts involved to get to that power level.
At an absolute minimum you'd be looking at:
$800 to $1.5k+ for a turbo (depending on what you want + extra if you decide to go for a better manifold)
$1250+ for a plug in like an adaptronic / nistune / link etc plug in
$600 for decent injectors
$200 for a better fuel pump at a minimum
$500-$1.5K for misc crap  for making the above work correctly or fix other problems you come across while doing it
$1k - $2k for a clutch to handle the increased output (if required)
$??? for any workshop work to fit the above (if not swinging spanners yourself)
$??? for tuning - highly dependent on who you go with
  • Like 1
The AFC is a nice bit of kit when turning up the boost a little on a standard car but at ~450hp at the wheels you are going to be asking for a lot more than what the AFC is capable of safely / sanely doing. The plug in will give you much more flexibility and safety in the tune, not to mention being far easier to tune and a better base to build modifications off.
Checkout www.apexi-usa.com/manuals/electronics/neo_manual.pdf
I have never used one personally but I am well aware of how it works. The sort of modifications that you are looking at is well beyond what this would be able to handle as it is really only meant to be able to manage fueling on a relatively stock engine and not deal with massively different injectors and a much larger turbo etc.
With what you are doing the nistune is an absolute minimum and really the engine management path you take is sort of dictated by who you are getting to tune it - you will get a better result using what they suggest / prefer rather than one they dont know / can't tune properly.
If you are poor don't buy rubbish you don't need. Just try to save up a few grand and in the meantime do some reading along the lines of what you have been advised above. Sell the AFC Neo.
Just to spell it out none of the items on your list will make your car go faster.
And don't feel bad that you don't know enough - we all have to learn - some of us the hard way by spending a lot of money that could have been used more wisely - so don't be in a rush - you can't do much until you can afford a bigger turbo and the bits needed to support it so just keep researching and saving!
  • Like 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
