Post up what you'd like to achieve (and the budget!) and we can offer some advice.
Try to set out what you want to do with the car and set a reasonable / specific goal for what you want to achieve - what you need to do / buy then flows from that.
Trex is on the money, read up on some of the other build threads or dyno results threads under "Forced Induction Performance" to see what others have done and it will prove invaluable to see what needs to be done and gives you an idea of the sort of costs / parts involved to get to that power level.
At an absolute minimum you'd be looking at:
$800 to $1.5k+ for a turbo (depending on what you want + extra if you decide to go for a better manifold)
$1250+ for a plug in like an adaptronic / nistune / link etc plug in
$600 for decent injectors
$200 for a better fuel pump at a minimum
$500-$1.5K for misc crap  for making the above work correctly or fix other problems you come across while doing it
$1k - $2k for a clutch to handle the increased output (if required)
$??? for any workshop work to fit the above (if not swinging spanners yourself)
$??? for tuning - highly dependent on who you go with
  • Like 1
The AFC is a nice bit of kit when turning up the boost a little on a standard car but at ~450hp at the wheels you are going to be asking for a lot more than what the AFC is capable of safely / sanely doing. The plug in will give you much more flexibility and safety in the tune, not to mention being far easier to tune and a better base to build modifications off.
Checkout www.apexi-usa.com/manuals/electronics/neo_manual.pdf
I have never used one personally but I am well aware of how it works. The sort of modifications that you are looking at is well beyond what this would be able to handle as it is really only meant to be able to manage fueling on a relatively stock engine and not deal with massively different injectors and a much larger turbo etc.
With what you are doing the nistune is an absolute minimum and really the engine management path you take is sort of dictated by who you are getting to tune it - you will get a better result using what they suggest / prefer rather than one they dont know / can't tune properly.
If you are poor don't buy rubbish you don't need. Just try to save up a few grand and in the meantime do some reading along the lines of what you have been advised above. Sell the AFC Neo.
Just to spell it out none of the items on your list will make your car go faster.
And don't feel bad that you don't know enough - we all have to learn - some of us the hard way by spending a lot of money that could have been used more wisely - so don't be in a rush - you can't do much until you can afford a bigger turbo and the bits needed to support it so just keep researching and saving!
  • Like 1
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
