hi guys new to this, and still learning
but the engine is blown and im trying to source a new one
ITS A TURBO CAR
i know the sticker and the chassis details vary, is there a website where i can type in the engine imprint and find out?
CAN ANYBODY HELP IDENTIFY EXACTLY WHICH RB ENGINE IT IS ??? PLEASE and THANK YOU
PICS SUPPLIED:
1. CHASSIS plate
2. imprint on engine
3. stick under bonnet
4.engine
Edited by Blak3
more info
https://www.sau.com.au/forums/topic/468766-help-determine-what-engine-i-have/
It's a RB25DET Neo mate. I've got the same bonner sticker stating 'RB25-DE', which is incorrect, must be from the same compliance shop.
If you want the full specs on your car try here http://nissan.epc-data.com or post your VIN here: https://www.sau.com.au/forums/topic/128496-vins-you-want-fasted/
The non-turbo RB25DE has a completely different crossover pipe and throttle body-to-plenum arrangement:
  • Like 2
  • 2 months later...
I know this is an older thread but checkout
partsouq.com website
Type in the blue jap vin number eg for yours.
ER34-004336 and every spec for your car turns up. And every part number.
Assuming you havent changed engines etc since it was new.
Heres the overview of your car when it was first built.
Cheers
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
