45v2 turbo on 21u rear housing
Hey guys just looking over my engine bay and remember reading a thread about all the 45v turbos and what the numbers mean.
i got given a spare turbo with the car when i bought it and was told it had a gtr turbo on it, (i knew next to nothing about turbos as this is my first turbo car), but i still didnt beleive him straight away as he had less teeth in his head than a toddler.
but looking at the two turbos, the one on my car now is 45v2 on a 21u rear housing,
and the spare is a 45v1 on the op6 rear housing.
just wondering if anyone knows why it would have been swapped around (as i can gather).
and should i change it back so that its running the 45v2 neo turbo on the op6 rear housing?
picking your brains as im not all the smart with this stuff.
cheers in advance
https://www.sau.com.au/forums/topic/468782-45v2-turbo-on-21u-rear-housing/
Don't forget GTRs have two turbos so each will not be massive. If all your stuff is stock it will be old and worn. If you can have the car off the road for a bit get Hypertune to do you a rebuilt turbo - either near stock if you want or more power if that's your goal.
Yeah i would like to get my turbo highflowed someday soon, but the question is. When i send it in, should i pull the 45v2 compressor housing off and put it with the op6 rear housing or is it better with the 21U rear house, any advantages or disadvantages with either combination. Or should i just call hypergear and ask them what they would reccomend, as its them that will be doing the work?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
