16194989_10155621831379386_1307480568990
The SAU Vic Go-Kart Championship is back and bigger than ever for 2017!
The 2016 Championship had fantastic support with a great turnout to all 3 rounds.  This year we have looked to keep the successful midweek formula that everyone enjoyed and we've added an extra couple of rounds, including one coupled with a cruise to Phillip Island and the final is a spring Sunday afternoon at LeMans that has always been popular over many years.
The points system for the championship has also undergone a shakeup.  We're going to use the V8 Supercar points system which will mean that events with more than one race will score points for each race, rather than just the final.  Don't worry if you can't make all 5 rounds - you drop your worst, so the winner is the best performer at 4 events.
 The championship starts with the fast, flowing outdoor circuit at AceKarts in Albion on Wednesday the 15th of February at 7:00pm.
 Our format includes 10 Minutes of Qualifying, followed by a 10 Minute Race and a 15 Minute Race.
 Championship points for this event will be in the Supercars Supersprint format.
1ST
2ND
3RD
4TH
5TH
6TH
7TH
8TH
9TH
10TH
11TH
12TH
13TH
Race A
Race B
150
150
138
138
129
129
120
120
111
111
102
102
96
96
90
90
84
84
78
78
72
72
69
69
66
66
Entry fee is $90 which includes all sessions
Sign in at 7.00pm
Drinks and snacks available from the venue.
To enter simply send paypal payment to - [email protected] with the reference GK17-R1
 Please get your entries in ASAP so we can confirm numbers.
DRIVERS LIST -
Matthew Doyle
Martin Sullivan
Sam Lehmann
https://www.sau.com.au/forums/topic/468786-sau-vic-go-karts-2017-round-1/
24 minutes ago, emts said:
Nearly forgot about this.
Happen to be in the country and it's near home!
Just entered
Good timing on the first round then for you :) Have added your name to the list :)
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
