Penrite 10w-50 vs 10 tenths?
Hi all,
Received a bottle of Penrite HPR 10W-50.  Reading posts and The Goods On Oils it seems the consensus is Penrite 10W-40 10 Tenths.  It is for an R33 GTR.
For the uneducated (me), I'd say the HPR 10W-50 is fine.  Before dumping the unknown oil in there, what are people's thoughts on the HPR 10W-50?
Cheers!
Edited by phatmonk
https://www.sau.com.au/forums/topic/468794-penrite-10w-50-vs-10-tenths/
Motul all the way for me but every car is different. Since you have the oil (one bottle? - what's that in litres>) just chuck it in and try it - your motor won't seize up  - just monitor heat, oil pressure etc and see how you go.
Go read the 200 pages of the dedicated oils thread here on sau.
It's about 330 pages. I had a look, TLDR it all... It's a forum; I used search, looked at the stickies and asked a question. That's what happens, right? Maybe I'm simpler than you, sorry.
HRP10 is a 10W-40 oil that has some additives that makes it a '50' when hot.
Racing 10 (10Tenths) is a full syn oil (more expensive, on par with Royal Purple, Motul Chrono, etc, group 5 oil I believe?)
Either will be fine. The Racing 10 has better shear properties at high temps/pressures. So if your engine cops some track work, I'd use that over HPR. HPR is fine for street driving.
  • Like 1
The huge oil thread has the answer, but it can take quite a while to trawl through it. You'll learn heaps though, people like to get technical around here (which is a good thing). Now go read the RB oil control thread :P .
Oh and on my GT-R, standard engine/boost/no oil cooler, I ran Racing 10 (10W-40) and Premium 5 (5W-60) on the track with no noticeable difference (going off engine noise and standard oil pressure gauge, car ran hot because I didn't flush the cooling system). Back in the early days I ran HPR10 for street duties and it was fine.
My answer was an actual answer. But I have used 15W-50 in my car for years and it has been fine. 40+ degree drift days at QR and I beat my engine harder than an unwanted red headed stepchild and it has never let me down. No oil cooler either.
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
