Penrite 10w-50 vs 10 tenths?
Hi all,
Received a bottle of Penrite HPR 10W-50.  Reading posts and The Goods On Oils it seems the consensus is Penrite 10W-40 10 Tenths.  It is for an R33 GTR.
For the uneducated (me), I'd say the HPR 10W-50 is fine.  Before dumping the unknown oil in there, what are people's thoughts on the HPR 10W-50?
Cheers!
Edited by phatmonk
https://www.sau.com.au/forums/topic/468794-penrite-10w-50-vs-10-tenths/
Motul all the way for me but every car is different. Since you have the oil (one bottle? - what's that in litres>) just chuck it in and try it - your motor won't seize up  - just monitor heat, oil pressure etc and see how you go.
Go read the 200 pages of the dedicated oils thread here on sau.
It's about 330 pages. I had a look, TLDR it all... It's a forum; I used search, looked at the stickies and asked a question. That's what happens, right? Maybe I'm simpler than you, sorry.
HRP10 is a 10W-40 oil that has some additives that makes it a '50' when hot.
Racing 10 (10Tenths) is a full syn oil (more expensive, on par with Royal Purple, Motul Chrono, etc, group 5 oil I believe?)
Either will be fine. The Racing 10 has better shear properties at high temps/pressures. So if your engine cops some track work, I'd use that over HPR. HPR is fine for street driving.
  • Like 1
The huge oil thread has the answer, but it can take quite a while to trawl through it. You'll learn heaps though, people like to get technical around here (which is a good thing). Now go read the RB oil control thread :P .
Oh and on my GT-R, standard engine/boost/no oil cooler, I ran Racing 10 (10W-40) and Premium 5 (5W-60) on the track with no noticeable difference (going off engine noise and standard oil pressure gauge, car ran hot because I didn't flush the cooling system). Back in the early days I ran HPR10 for street duties and it was fine.
My answer was an actual answer. But I have used 15W-50 in my car for years and it has been fine. 40+ degree drift days at QR and I beat my engine harder than an unwanted red headed stepchild and it has never let me down. No oil cooler either.
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
