dave123456789 r32 gtr
Been meaning to make a thread on this for a while. Story goes like this..
I have been wanting a R32 GTR for as long as I can remember, was always the dream car to have since my younger days when everyone had gtsts and gt4 skylines. I had been saving furiously for a few years trying to have a crack at the property market so had some money sitting idle, the pine for a gtr started to get stronger and stronger then one day I just went for it. I had not long turned 30 so thought of it as a present to myself. After a bit of a hunt this is what I ended up with.
Originally wanted a black one or that dark grey they come out in but after seeing white in the flesh I was sold. Also had to be a 1994 model as I wanted the latest one you can get.
1994 Nissan Skyline GTR
82,000ks
Tomei type A cams 264
Adjustable cam gears (no name brand and not dialled in yet)
Aftermarket fuel pump
Mines ECU
Straight through exhaust with 1 rear muffler
Apexi induction kit
Lowering springs on bilstein shocks
Cusco 2way LSD
Stock turbos at stock boost (10-11psi)
N1 side skirts, rear end caps and headlights.
Tomei gear knob my lovely lady got me for Christmas as previous one was the only thing I hated about the car
So far have only changed the wheels, still working out which route to go with the turbo chargers. I sold my Evo 5 so freed up some extra coins for this. Here's some pictures
  • Like 1
https://www.sau.com.au/forums/topic/468806-dave123456789-r32-gtr/
13 hours ago, KiwiRS4T said:
Nice car.
You will need an aftermarket ECU (e.g. Link, Haltech) and watch this:
Hey mate.
Still unsure if I am going to take the plunge and crank heaps more power out of it. For now it looks the part, sounds awesome and is quick enough for the streets. Im not planning on tracking this. I did manage to do a 13.108 at 108mph down the 1/4mile with this setup. Few more pounds of boost pressure and I could have probably cracked a 12.
5 minutes ago, jmknights93 said:
Looking mighty neat! Loving the choice of wheels.
Cheers mate. They are 18x9.5 -15 BBS RS replica wheels. fit good and didn't even need to roll the guards at this height with 265/35 tires. So they are not the real deal but look good. Still trying to work out what color to change the centre bit to, thinking a dark grey or a dark bronze/gold.
Sounds like the same wheel combo as a mate of mine. Sits nice!
  • Like 1
Yep I love the look of those wheels.
Any idea where he got the centre caps? Are those replicas also? Cheers
17 minutes ago, niZmO_Man said:
I think you mean +15 :P. They look awesome, perfect sizes/offset for R32 GT-R.
Haha my bad. Im used to oldschool rwd Toyotas where everything decent is in negative offset.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
