JaysCefy
Hello all.  I'm a US military member stationed in Japan and have just bought a 92 Cefy.  I haven't actually taken possession of it yet, but it's on it's way (shipping to Okinawa from mainland).  The car is RB20DET, factory 5 speed so wherever I go next it can come with me. Even to the US with it's absolutely ridiculous import laws.  While in Japan my plan is mostly minor stuff, but once she gets back to the States with me (whenever that may be) I plan to put my RB25DET and trans in.  Looking forward to learning a lot here and will be relying on you guys since the US never got the Cefy.
  • Like 2
https://www.sau.com.au/forums/topic/468816-jayscefy/
No pictures yet because I didn't think to save any from the dealer where I bought it.  At least on Okinawa and among US folks, Cefy's are pretty rare. I've only seen one in person. Countless Skylines of all types, JZXs, RX-7s and Supras.  Not that many C33s or A31s at all.  And I imagine even fewer in the US.
https://www.sau.com.au/forums/topic/468816-jayscefy/#findComment-7807293
they expensive over there?
not too bad in the nz market if you want to have a nosey.
http://www.trademe.co.nz/Browse/CategoryAttributeSearchResults.aspx?search=1&cid=268&rptpath=1-268-&sidebar=0&5=&14=&18=0&18=0&24=0&24=0&searchregion=100&54=CEFIRO A31&searchbar=1&generalSearch_keypresses=16&generalSearch_suggested=0&generalSearch_suggestedCategory
https://www.sau.com.au/forums/topic/468816-jayscefy/#findComment-7807297
The price depends on several things. Mine was a good deal, $4300 US shipped from mainland, the body looks to be in really good condition and interior looks more or less brand new (Japanese tend to take really good care of their cars) but it has about 204000 km on it, which is fairly high for Japan. My 91 RX-7 that died on me only had 105k when it let go.
  • Like 1
https://www.sau.com.au/forums/topic/468816-jayscefy/#findComment-7807300
    • Tried them, they leaked. I also foolishly bought some random rubber ones that leaked too.  Genuine and not looked back.    As always though sample size of one, and I could have made a mistake installing them.
    • Technically still manual process to set it first time though
    • Shit job but not hard. I'd use a piece of wood to knock the plastic lid open to avoid damaging it, use a vacuum to clean up the fuel sender lid also so crap doesn't fall in. I'd probably do pump and filter at the same time since you're already in there, I reused my OEM sock after a quick clean since the one provided wasn't long enough. Could also hardwire your pump if you feel inclined.
    • Supercheap auto sell this: https://www.supercheapauto.com.au/p/pat-plusquip-fuel-tank-lock-ring-tool---universal-kit/SPO3564082.html I own this and if you HAVE PATIENCE you can remove it without snapping lines and generally being incredibly angry, then said at doing this job. Sadly I've removed the pump about 75,000 times over the years. I don't know if you're a large lad or a smaller lad but my advice to you as someone who is 185cm is if you are my height or smaller, is to sit in the boot and take your time. Yes you can put the seal on. The seal goes over the white thing/lid (you will see how it 'slots' in) then the whole assembly presses into the tank. then you screw the lock ring on. I spent so much time doing things the wrong way by trying to mount the seal into the tank first, then putting the white fuel hat on in the space provided. Put it together first then it'll all go in. But seriously be careful about removing the hoses AND where the removal tool is moving relative to the plastic pipes coming out of the lid when you've removed it. IT IS BRITTLE So brittle in fact I have two spare lids, and would recommend buying a spare and having it handy before attempting to do this. May as well throw https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD in the tank as well, as this uses all stock plugs and such. You may need to/strongly recommend you re-use your OEM fuel sock or use the one supplied with a length of hose so it sits at the stock height.
    • The tension is automatic....if you follow the installation instructions Self adjusting tensioners are used when the chain/belt is expected to stretch during it's service life, but the downside is the tensioner itself can fail and cause a problem, while the RB system is locked once it is installed and doesn't have that risk
