V28VX37 Posted January 27, 2017 Share Posted January 27, 2017 Blown Neo bottom end - Next steps? Welcome to the continuation thread to Blown Neo head gasket - Next steps https://www.sau.com.au/forums/topic/467066-blown-neo-head-gasket-next-steps/ Soooooo another track day, another drama. Did Sandown yesterday, first session went well but started having more and more issues as the day wore on. The engine starting pushing coolant again and had boiling coolant in the overflow despite checking and re-bleeding the system (thanks once again for lending a hand Bill!!). In the last slow session it decided to blow off the PCV hose and push oil + smoke from rocker cover breathers. Sounded like a Rex too. I got it towed to the workshop and the verdict came in this afternoon, bottom end is gone. It's lost compression on cylinders 3, 5 and 6, and I'm guessing that's probably the root cause for the originally presumed head gasket issues too, so all that expense is likely to have been in vain. If 2016 was the year of dead celebrities looks like 2017 is the year of dead RB25's (hi Johnny)... This one lasted about 150k and ~10 track days @ 275 rwkw so there you go. Silver lining: My last Sandown PB was 1:34.06 from December 2015 (!) because I was s__t and/or #becausedrama every single time in 2016 ... I only got some 20 laps in yesterday but did grab a string of PB's: 1:32.36 1:32.17 1:31.81 1:30.731:29.58 So at least this Neo died in style. Sidenote: The RDA rotors worked wonders with the Intima SR's & brake air guides, and the Nismo 1.5-way is absolute magic on the track. Anyhow, onto the next steps: I think it's time to get out whilst winning and stop throwing good money after bad. Other than the engine, it's a good sorted car with a 5-page long mod list. The options are: Find a replacement engine, get it swapped over and sell is as a sorted, running & regoed street and track car Buy a replacement block, get the freshened up head transferred onto it, then as above Stop spending stupid money, pull out all the parts worth anything, and unload as a rolling shell Something else, you tell me? Cost of options 1 & 2 will probably be in the 3-5k range (workshop labour) but you'll also get more in selling a proper running car. Flip side, second hand engines or blocks rarely come with warranty. Having spent hundreds and hundreds of hours and many many more $$$ on this car I was kinda hoping to sell it as a turnkey street & track package for someone else to enjoy, so would really hate to part it out... Plus I don't think it's worth much that way, and you'd end up dealing with a whole heap of tyre kickers. What do you guys reckon? Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/ Share on other sites More sharing options...
KiwiRS4T Posted January 27, 2017 Share Posted January 27, 2017 Option 1 should not cost more than $3K http://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/auction-1250747254.htm plus installation should not be more than $1k Maybe things are different in Aus. Try advertising it as a project with lots of work already done - just needs new short block and see what offers you get. 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807369 Share on other sites More sharing options...
AngryRB Posted January 27, 2017 Share Posted January 27, 2017 RB30 time $1k 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807386 Share on other sites More sharing options...
blah_blah Posted January 27, 2017 Share Posted January 27, 2017 Damn badluck dude. If you need cheaper workshop labour let me know 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807394 Share on other sites More sharing options...
V28VX37 Posted January 27, 2017 Author Share Posted January 27, 2017 Thanks guys. 13 hours ago, V28VX37 said: ... The options are: Find a replacement engine, get it swapped over and sell is as a sorted, running & regoed street and track car Buy a replacement block, get the freshened up head transferred onto it, then as above Stop spending stupid money, pull out all the parts worth anything, and unload as a rolling shell Something else, you tell me? ... One more option is to get the engine fixed up and at the same time put it back to stock as much as possible, and sell as a running stock car + separate turbo/exhaust/intercooler/intake/oil cooler/gauges/diff etc. Just trying to work out which option will minimise further loss of $$, thoughts? I've had a look around the usual suspects eBay and Gumtree and there's basically nothing at the moment in terms of Neos, so might need to start calling through the wreckers on Monday. Can you check engine numbers on FAST? Is there a way to confirm year/type of an RB25 block/full engine based on the engine number? I need to find a 2WD Neo unit, so that there's no further mucking around. Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807408 Share on other sites More sharing options...
Kinkstaah Posted January 28, 2017 Share Posted January 28, 2017 Put another stocker in. Continue enjoying car.If changing direction... Put stocker engine in, sell car. You cold advertise the parts and remove them as they actually sell. (If you have stock stuff to replace with)Dirty 30 is another option but not if you want a RWC or plan on selling. Would stick with another neo.You may sell it with no engine, but I expect the price you get will be less in your pocket than it would be selling a running car, after also paying for the engine being replaced. 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807438 Share on other sites More sharing options...
V28VX37 Posted January 28, 2017 Author Share Posted January 28, 2017 11 minutes ago, Kinkstaah said: Put another stocker in. Continue enjoying car. If changing direction... Put stocker engine in, sell car. You cold advertise the parts and remove them as they actually sell. (If you have stock stuff to replace with) Dirty 30 is another option but not if you want a RWC or plan on selling. Would stick with another neo. You may sell it with no engine, but I expect the price you get will be less in your pocket than it would be selling a running car, after also paying for the engine being replaced. ^^^ Re last line, yep that's what I'm thinking too. I'll keep looking for an engine. There's a decent looking block in the FS section but I have no idea how much more work it'd be to mate the existing head onto that, compared to a straight engine swap. Probably lots. With this option I'm also wondering if I can reuse my recently installed OEM HG and ARP head studs, or are they disposable items? Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807441 Share on other sites More sharing options...
GTSBoy Posted January 28, 2017 Share Posted January 28, 2017 Studs yes. Gasket goes in the bin. 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807444 Share on other sites More sharing options...
Kinkstaah Posted January 28, 2017 Share Posted January 28, 2017 I have a spare OEM HG for sale But in all seriousness I didn't reuse any of my Tomei Metal HG's even though they claim to be re-usable. Just didn't want to ever risk it. It would be cheaper to keep the head you have, but its a lot tricker to trust a block unless you know how to inspect it and know it's fine when it's apart. It will save you to do that if you can. It'd be more labour but the block will cost less than an assembled engine. Probably still work out in your favour and then you don't have a spare, perfectly working head. Then again someone may want that spare perfectly working head for a RB30. Or you could just get a great deal on a fresh RB28. 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807454 Share on other sites More sharing options...
KiwiRS4T Posted January 28, 2017 Share Posted January 28, 2017 Contact Tony (Blah_Blah above) who may be able to do the labour, or knows of someone who can, and get some indicative pricing for the main options (complete motor swap or replacement block). BTW I have reused the same Tomei H/G three times with no problems - but don't think you can do that with other types. 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807459 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 28, 2017 Share Posted January 28, 2017 oh fek, not you as well!!! 1 Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807532 Share on other sites More sharing options...
MrStabby Posted January 29, 2017 Share Posted January 29, 2017 On 1/27/2017 at 8:48 PM, V28VX37 said: I got it towed to the workshop and the verdict came in this afternoon, bottom end is gone. It's lost compression on cylinders 3, 5 and 6, and I'm guessing that's probably the root cause for the originally presumed head gasket issues too, so all that expense is likely to have been in vain. What's the logic here? Lost compression wont cause head gasket issues, but head gasket issues can cause lost compression. Are you saying that the head gasket fix didnt take, or that there was a piston/valve issue and that the HG was ok all along? Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807567 Share on other sites More sharing options...
V28VX37 Posted January 29, 2017 Author Share Posted January 29, 2017 14 minutes ago, MrStabby said: What's the logic here? Lost compression wont cause head gasket issues, but head gasket issues can cause lost compression. Are you saying that the head gasket fix didnt take, or that there was a piston/valve issue and that the HG was ok all along? Correct, one theory is that there a was an underlying piston/ring issue and that the HG was ok-ish all along. The HG issue was always really difficult to diagnose as on the street the car was fine, on the dyno it was mostly fine, and only on the track did it start chucking coolant – which occurred again on Thursday even after the head refresh, new HG and head studs. It was comp tested before the HG change and returned reasonable figures so the bottom end was deemed ok. Also powerwise it ran pretty much the original numbers on the dyno after the new HG so I thought it was all a-ok now... But yeah it's an RB so who knows really. Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807572 Share on other sites More sharing options...
MrStabby Posted January 29, 2017 Share Posted January 29, 2017 Weird. So temperatures were ok? (do you trust your temp gauge?) Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807582 Share on other sites More sharing options...
V28VX37 Posted January 29, 2017 Author Share Posted January 29, 2017 3 minutes ago, MrStabby said: Weird. So temperatures were ok? (do you trust your temp gauge?) Yes and no. Yes in the sense that I didn't cook it this time and the temps started dropping once you backed off the loud pedal. When I cooked it at Sandown last year the temps kept on rising even with no throttle and ultimately hit 125C for water. The root cause for this back then was a minor leak in the cooling system (that I didn't pick up in time), which depressurised the system and significantly reduced its cooling ability. No in the sense that on Thursday the car would only take 1-2 hot laps before hitting the warning level for water and oil soon thereafter (set at 105C for water and 120C for oil). This is with a brand new Mishimoto radiator and a 19-row oil cooler, and IMHO it should be able to take more than a lap and a half... I trust my gauges, genuine Defis and sensors all around. I also watch them like a hawk since last year's incidents, to the level that it's actually not that much fun driving as I'm just waiting for s__t to break again. Which it did. Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807586 Share on other sites More sharing options...
MrStabby Posted January 29, 2017 Share Posted January 29, 2017 52 minutes ago, V28VX37 said: No in the sense that on Thursday the car would only take 1-2 hot laps before hitting the warning level for water and oil soon thereafter (set at 105C for water and 120C for oil). This is with a brand new Mishimoto radiator and a 19-row oil cooler, and IMHO it should be able to take more than a lap and a half...d. Yeah that seems very quick to be getting to your limits. Did you push past 105/120 on Thursday? At what temp did the coolant come out the overflow? (or was that from heat soak after stopping the motor?) Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807591 Share on other sites More sharing options...
blah_blah Posted January 29, 2017 Share Posted January 29, 2017 Interesting re your water and oil temps Mines a rb25 neo with a 13row oil cooler? Street temps generally Water and oil 75 to 80c. Track 5 hot laps i think Water still around 80 to 90max. Oil around 105-110c max Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807592 Share on other sites More sharing options...
MrStabby Posted January 29, 2017 Share Posted January 29, 2017 Blah_blah - more or less than V28s 275kw? Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807595 Share on other sites More sharing options...
blah_blah Posted January 29, 2017 Share Posted January 29, 2017 18 minutes ago, MrStabby said: Blah_blah - more or less than V28s 275kw? On e85 360 to 385rwkw When i had no oil cooler. Yeah i'd see 120c after about 2 to 3 hot laps. Even when i had a stock turbo and and stock engine bout 200rwkw it would hit 120 to 130 after a few laps Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807596 Share on other sites More sharing options...
V28VX37 Posted January 29, 2017 Author Share Posted January 29, 2017 1 hour ago, MrStabby said: Yeah that seems very quick to be getting to your limits. Did you push past 105/120 on Thursday? At what temp did the coolant come out the overflow? (or was that from heat soak after stopping the motor?) Nope backed off at that point. Overflow level always rose after a session, at one stage about 10cm so heaps. That's when it spat a bit out at the top of the overflow tanks. Bill and I bled the system in the afternoon, there was heaps of air in there at that point, too. 1 hour ago, blah_blah said: Interesting re your water and oil temps Mines a rb25 neo with a 13row oil cooler? Street temps generally Water and oil 75 to 80c. Track 5 hot laps i think Water still around 80 to 90max. Oil around 105-110c max Yep absolutely no way I could do more than 2 hot laps at all. Which is strange, as when I first started tracking the car I could do that much with stock rad and no oil cooler, so something's definitely amiss. 52 minutes ago, blah_blah said: On e85 360 to 385rwkw When i had no oil cooler. Yeah i'd see 120c after about 2 to 3 hot laps. Even when i had a stock turbo and and stock engine bout 200rwkw it would hit 120 to 130 after a few laps ^^^ Same here. Link to comment https://www.sau.com.au/forums/topic/468826-blown-neo-bottom-end-next-steps/#findComment-7807611 Share on other sites More sharing options...
