It's not a good idea to wind up boost with the stock ecu on that engine. This street racer found out the hard way.
That pic suggests not enough boost as it was just bent, not a clean break, amateur at best[emoji12]
  • Like 3
19 hours ago, Dose Pipe Sutututu said:
will need fill custom dose pipe, going to be hard to find a 10" pipe and bends lol
Nah, grab some huge sheetmetal and roll it.
Easy af
On 23/02/2017 at 8:10 AM, PatMol said:
Try skylines spares in Sydney he has neos on the shelf.
Thanks Pat, that did the trick!
Just paid for a Neo long engine, wasn't cheap but hopefully it will live up to the expectation.
Man there's a Neo drought out there big time...
  • Like 1
So , question has to be asked....identified why you are knocking around the engine?  I  would expect a NEO to be very happy a the power level you are running
Nope, we don't have a 100% clear answer at the moment. My suspicion is that what was originally identified as a blown HG (after much debate, since the evidence was inconclusive) ended up being a more sinister underlying issue with the engine. My best guess at the moment is a crack in the block but for a full diagnosis we'd have to tear down the bottom end and possibly crack test the block. I'm not interested in throwing any more good money after bad at the moment frankly, so we may be left guessing for a while.
And yes I've run it at 20psi / 275rwkw for a while, which is meant to be within the 'safe' range for a Neo. It died after about 8 track days so I'm wondering if there's a street 'safe' and a track 'safe' power level, and how different they might be...
  • Like 1
Send me your tune file, I'll see what's going on there.
When I tune for track cars I always tune the entire mid range below MBT, taking at times 3 to 5 degrees out. This limits the amount of peak torque the motor can make thus keeping it together a little longer. Yes EGT goes up, but just richen it up close to 11 afr (on gasoline scaling) for E85. On 98RON I drop it under 11 afr. I don't aim for a flat AFR which most Internet experts like.
  • Like 1
Thanks man will do! I've got the Consult cable but do I need a full version of the Nistune software to grab the tune?
hrms.. good question, if not just do a screen shot of the timing table and roughly tell me which load cells it's hitting and/or what TP Load is roughly equal to what boost
Looks like there is a trial version: https://www.nistune.com/index.php/support/software-downloads
I'll check it when I get the car back home, hopefully in two weeks or so...
Ok I may have a buyer for the original refreshed cylinder head, any tips on how to package up one properly for safe delivery?
Bubble wrap the f**k out of it.
  • Like 1
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
