Hey guys i have a widebody r32 with 285's all round with 25ml spacers on back and a r34 neo engine with the20160826_095314.thumb.jpeg.b2a0d0f5a59c920160826_095314.thumb.jpeg.b2a0d0f5a59c920160826_095314.thumb.jpeg.b2a0d0f5a59c9 33 box and twin plate clutch making 340 on 20psi, and my boxes last maybe 100kms and start whining and another 100kms and 3rd gear has gone 3 times, ive done 6 axles and a half shaft in just under 5000k's and a centre bearing and clutch had to be sent away to be done because it started slipping.... my question is can any body help as to why im doing it?? i didnt clutch kick thor this box or drop it in 2nd or 3rd just fed it on and after 100k,s its whining already, it had a 2way cussco in it and i swapped it for a locked diff and need some ideas on what to check e.g gearbox and diff aligned right, measurements, heights, crossmember, etc etc ive read maybe its the clutch is to harsh. i think its a extreme brand i know its a twin plate, and is there anyone in vic i can take it to that can help me??? My mates box in a 33 lasted over a year with 530rwkw smashing it and it still hasnt blown, im on 3rd box and am its about to blow, im over it and need help pls guys,
https://www.sau.com.au/forums/topic/468833-need-help-or-ideas-pls-fellas/
Listen, if your in Melbourne, the best skyline performance centre is Racepace performance in Bayswater, trust me take your car there and they will put a smile to your face, they specialise in gtr's, I take my car there, they will get to the bottom of your problem[emoji106]
  • Like 1
Twin plate clutches aren't made to be slipped, it kills them quick
Locked diff puts more strain on gearbox and axles
Check that everything is lining up perfectly straight when it is installed
90% of the time in this situation, it is the driving style influencing it
I thought it was 2 but i only fed it on this box and it felt like The best box so far,i used to clutch it up 3rd at 100 so i changed driving style fast lol, and my car sounds supercharged after not dropping it once, it whines that much after 100kms in my car and no track days either. i think its the rubber on crossmember dont hold box up straight or right height, somethings up i just dont know what measurements to check from where....
340kws and you're doing clutch kicks with 285 wide tyres? what kind of locked diff?
what did you do with all the old boxes you've replaced? did you crack any of them open to see if there was anything visibly wrong with them? what damage was on the axels and half shafts?
It's also possible the box you most recently put in has tired bearings.
But yeah consistently snapping axles comes from too much pressure - this is caused by A. Too much power / traction B. Misaligned parts or C. Driving the vehicle like you stole it.
I did have the slicks on and it was hooking up second like a boss but its consistently broke shit over 18 months and i didnt have a licence for 12 of it lol and only done 2 track days, sprint races not drifting, it has to be some alignmentissue but i dont know what to check
Slicks and a lock diff will do that...
It's all about the weakest link in the chain
In most cars with an open diff, this is the traction of a single wheel, which breaks before anything else (wheelspin), but means the drivetrain has less stress on it because there is less resistance to the rotational force at the other end (gripping the road). With an LSD or locked diff, you have effectively multiplied the resistance by two.
If you then strengthen the tyres with more grip, you shift more pressure onto other components in the drivetrain, such as the clutch. If the clutch slips, this means there is a limit to how much pressure is exerted on the axles or gearbox and the clutch is giving way first. Upgrade the clutch and this weakness disappears; suddenly the gearbox and axles have more pressure exerted on them...if the pressure is too great, one of these will snap.
Side note: Clutches are generally cheaper to replace than gearboxes, hence I often say there is such a thing as too heavy a clutch.
  • Like 1
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
