Custom gauge fit R34 GTT only!
Hey guys,
I've been requested to do a DIY on the gauge install in my GTT. ill try to include as much info as possible!!
BTW i don't take any responsibility for anyone's attempts and if you damage anything you have no one but yourself to blame.
Now, We've all seen setups when the aftermarket gauges are just jammed in, honestly that would drive me up the wall.
To remove the factory gauge cover holder
- pop out center vents located under factory gauges, use a plastic popping tool not a screwdriver. unplug hazard light
- two screws hold the gauge pod in, after undoing these you can lift the unit and you'll find one connector for all three gauges
- on the inside, two screws hold the gauges inside the pod
Once separated this is what you're left with
- Remove the 6 screws on the front to take off the plastic cover
- I cant remember how many screws hold the actual gauges, remove them all
- Now that its separated, this is whats left.
- Next step is to pull the aftermarket gauges apart.
These are shadow (defi copy) 60mm
- Using a tiny flat blade, had to bend out the bezel edge so the face could be removed
Bezel, Glass and gauge pulled apart
60mm gauges are a snug fit, all i did was align, pressure fit all three and hot glue holds it all together
Power, Earth, ACC and Illumination all can be tapped from original harness from memory
To finish it off, i ordered a new plastic face from Nissan. think it was about $40 AUD
Final Assembly!
Enjoy!
Edited by stump_69
  • Like 5
https://www.sau.com.au/forums/topic/468841-custom-gauge-fit-r34-gtt-only/
  • 3 weeks later...
  • 2 years later...
  • 2 months later...
On 26/06/2019 at 2:29 AM, 25SKY said:
@V28VX37
im looking to do the same as you, what did you use for a backing / brace to hold them straight and level, also any glue used  ?
any tips, tricks or info would be awesome man
Hey mate, it's a pretty simple setup really. There's an existing mounting rail that the old TV unit bolted on to - I just made little 'shelf' out of a Bunnings bracket to hook onto that.
I used some cheapo aftermarket gauge pods with the backs cut off, just taped onto that shelf with double-sided tape from memory.
The triple gauge cluster housing then just sits around the whole set of three gauge pods, and luckily the standard gauge cluster holes are just the right size for the Defi gauges.
  • 1 month later...
