M35 Airbag Woes
Hi all,
Been a while since I've posted on SAU.
Recently picked up a beautiful example of an M35, and it has been flawless aside from this one minor issue.
It's intermittently throwing an airbag code and flashing the light on the dash. It first happened the day I bought it home and the wife jumped in the car with me. We had been to a couple of places that morning already, and it wasn't until we were halfway between one place and another that the light came on.
I took the car to work and plugged it in to read and clear the code.
All was then fine until Friday just gone, where I had 2 passengers in the car, and I had been out and about with them for a couple of hours. It was only on the way home with the same people sitting in the same seats that the light started flashing again.
Back to work today, and I plugged it in to read the code this time. Once again, it's the same code..
Both times the code is appearing under DTC history, so it's only active when there's someone sitting there. I'm assuming it's something to do with the passenger seat at the front.
Ideally, I'd like to properly fix this, but failing that, I'm willing to do the resistor trick to sort it out.
Can anyone point me in the right direction of the wiring/plug/sensor that is causing this?
Cheers,
Ben
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/
I have the same thing, a different code. I see your post on facebook, it has to be some plug/contact needs a good cleaning, our best bet is to pull the seat out and check all the wiring/connection, will dig into it one day.
I don't believe this will effect the deployment of the airbag if needed.
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7807976
If the airbag lamp is lit it's likely not going to deploy. Most likely it's the switch under the seat that is faulty, but check the plugs too. Might be best to try and bypass it like I did years ago when I fitted Bride seats.
  • Like 1
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7808468
How do you bypass it Scotty?
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7808476
  • 2 months later...
no problem.
theres only 4x14mm bolts holding seat in.
under the seat there is a yellow plug ( theres only 1)
unplug and wire a 2.2 ohm resistor in ( theres only 2 contacts so you cant f&% it up)
personally I disconnected the battery and waited a little. I'm afraid of setting the ram off.
also I tested before bolting the seat back down. otherwise its stupid easy.
  • Like 1
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7823326
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
