M35 Airbag Woes
Hi all,
Been a while since I've posted on SAU.
Recently picked up a beautiful example of an M35, and it has been flawless aside from this one minor issue.
It's intermittently throwing an airbag code and flashing the light on the dash. It first happened the day I bought it home and the wife jumped in the car with me. We had been to a couple of places that morning already, and it wasn't until we were halfway between one place and another that the light came on.
I took the car to work and plugged it in to read and clear the code.
All was then fine until Friday just gone, where I had 2 passengers in the car, and I had been out and about with them for a couple of hours. It was only on the way home with the same people sitting in the same seats that the light started flashing again.
Back to work today, and I plugged it in to read the code this time. Once again, it's the same code..
Both times the code is appearing under DTC history, so it's only active when there's someone sitting there. I'm assuming it's something to do with the passenger seat at the front.
Ideally, I'd like to properly fix this, but failing that, I'm willing to do the resistor trick to sort it out.
Can anyone point me in the right direction of the wiring/plug/sensor that is causing this?
Cheers,
Ben
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/
I have the same thing, a different code. I see your post on facebook, it has to be some plug/contact needs a good cleaning, our best bet is to pull the seat out and check all the wiring/connection, will dig into it one day.
I don't believe this will effect the deployment of the airbag if needed.
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7807976
If the airbag lamp is lit it's likely not going to deploy. Most likely it's the switch under the seat that is faulty, but check the plugs too. Might be best to try and bypass it like I did years ago when I fitted Bride seats.
  • Like 1
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7808468
How do you bypass it Scotty?
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7808476
  • 2 months later...
no problem.
theres only 4x14mm bolts holding seat in.
under the seat there is a yellow plug ( theres only 1)
unplug and wire a 2.2 ohm resistor in ( theres only 2 contacts so you cant f&% it up)
personally I disconnected the battery and waited a little. I'm afraid of setting the ram off.
also I tested before bolting the seat back down. otherwise its stupid easy.
  • Like 1
https://www.sau.com.au/forums/topic/468852-m35-airbag-woes/#findComment-7823326
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
