Hi all,
Looking for some feedback before I head down the expensive road of ripping off my exhaust manifold.
So I upgraded the std snail to a hypergear ATR43SS2 with relevant supporting mods, so far I have managed 16psi out of it, hit a brick wall due to slipping clutch on dyno and some other small issues, so a majority of the issues are all fixed bar one that is really driving me nuts as I want it sorted before it goes back on to crank it up.IMG_1485768063.601685.jpg.1354415ab33cc4
So I'm having issues with the gaskets that sit between the spacer and the manifold, so far have gone through three different type of gaskets that all just keep blowing out, one lasted about a week with relatively easy driving, one two days then the other about two weeks.
I've been told numerous fixes / could be caused to the issue.
The last resort is rip it off and check the surface of the manifold then if all fine to have it welded, I'm a little reluctant to pull it off as I know il be up for re-tapping the bolts etc etc.
Wondering if anyone has any feedback.
https://www.sau.com.au/forums/topic/468858-rb25-manifold-gasket-issue/
Random observation but the manifold spacer supplied with my ATR43SS3 is noticeably thicker than yours:
Maybe check with @hypergear which one it's meant to be, and/or if the thickness matters at all?
5 hours ago, ADM33T said:
It's just doing my head in for something that should be so simple.
But I guess when we start modifying it should be expected.
It's not really that you've modified anything.  It's not as though you're running monster exhaust manifold pressure.  But if you try to slap a slab of steel between 2 other surfaces and don't ensure that all 4 faces are straight and true (and collectively parallel!) then you're spinning the roulette wheel.
The other issue I guess is that il have to keep approx $400 aside for when I snap a bolt to get off, everyone I have spoken to has said that the bolts will def snap.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
