Next SAUWA Meet / Eat / Cruise.
Hello guys n girls lets kick this event category off in the forum.
Should be easier to follow than Wasteland.
Ok i mentioned about 2weeks ago to have a get together on 3rd 4th February.
3rd will be Friday and the big danny green fight is on.
So
Im thinking it would be a good idea to have it on Saturday 4th February.
I love this place and would love everyone to experience it.
http://www.highwycombetavern.com.au/
Great place
Big Carpark!
CHEAP FULL SIZE PINTS FROM $4.90 [emoji481] (please drink responsibly)
REAL WOODFIRE BIG PIZZA FOR $10[emoji487]
Friday are real busy but Saturday are ok.
Outdoor area for smokos and big screen
Indoor lounge with pub special.
And a restaurant option bit more formal.
Address:
530 Kalamunda Rd, High Wycombe WA 6057
Time:
1830
When:
4th February 2017
Who:
Everyone with a JDM
Rules:
Please read event sticky
Please reply if coming or any small changes like time. [emoji2]
1485869221739.thumb.jpg.d2a6e2e97b2d88c01485869201834.thumb.jpg.829be9e8c0376139
  • Like 1
https://www.sau.com.au/forums/topic/468874-next-sauwa-meet-eat-cruise/
Hello people that i don't know and just tagged you in this. I do apologize if you sold your JDM or moved states and want to forget SAU.
But im doing my best to make SAUWA big again !!!
Ill try tag about 45 but if 5 show up its worth it!
@dan_the_man@IMACUL8@Pal@antonio6183 @2fardown@EXEMPT@REMANIS@GODZILR32@mzlr32k@niran@R34@just kris@Diomedes_@StaceyR34GTT@Topaz @Mr.Keets @[YTRY4]@karbie@alvis@scarvo@chris260@Holly@TrevR32 @180j @mz.qiksky@Vinay1789@J3NKINS@MLCrisis@Sledge038@RBert@Wesley James R32GTR@YoLoBaCh@BiscuitTin@shane344@Socrates@Hattori Hanzo 69@L33SH@Josh080691@Footo@JH32 @ichi-go@PSIKO@tricstar@Hanaldo@jay-rod@Bren444@reNEGaDe88@Rekin@turboedsloth @10 4 @104@Nick_GTR@RB335@frostyboy@owen1r @sin-
  • Like 2
Ill try tag about 45 but if 5 show up its worth it! @Mr.Keets
Mr Keets has numerous JDM cars but is currently in sunny Africa, I'll let him know you've invited him though, I'm sure he'll be flattered :P
  • Like 2
I'll see what my work load is like. Will be in a jeep though as the 32 still isnt drivable
I'll try if I get my car back/get back to Perth on time
Drive Colin's to Perth and I'll bring ya home ;)
  • Like 2
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
